Technical Replacement Springs for a 50 Olds
Discussion in 'The Hokey Ass Message Board' started by BJR, Apr 5, 2026 at 10:05 PM.
  1. BJR
    BJR
    The 50 Olds I bought has air bags. I am thinking about replacing them with springs. What has anyone used to lower the car an inch or two, and handle good?
  2. Dago 88
    Dago 88
    IMG_3740.jpeg I am in Australia, and I used late 70’s Ford Falcon coils in the front and early 70’s Holden Torana coils in the rear. The Torana is an Aussie produced small Chev, probably the size of a Nova, I’m sure you will find an equivalent spring in the US. Good luck.
    BJR likes this.
  3. Marty Strode
    Marty Strode
    1968-72 GM intermediate rear coils will bolt in. There is quite a range of springs from a Chevelle to an Olds Vista Cruiser wagon.
  4. DDDenny
    In_The_Pink and BJR like this.
  5. rockable
    rockable
    If you call Eaton Detroit Springs and tell them that you want stock springs -2", they will make them for you.....and they will be a 2" drop. I've used them several times and the lady that answers the phone is the owner's wife. She's been doing it a long time and she will steer you to what you want.
    https://www.eatondetroitspring.com/
  6. Damon777
    Damon777
    I will vouch for Eatons as well. I had cut stockers under my 50, and it was too much. Did 2" drop eatons up front and couldn't be happier. I did 79 elcamino springs in the back, but they matched the cut stock fronts, so I don't have them in currently.
  7. Bird man
    Bird man
    from Milwaukee
    I used 70 BB Chevelle springs with air in front of my '57. Took 1.5 coils off and the car sits 1 inch lowered. The resulting spring rate is more performance oriented.
    Handling is very subjective, some like a soft, flaccid ride. The 39-57 Pontiac & Olds suspensions are very similar. The Olds front suspension is basically the same from 39-53.
    I found KYB shocks for a 61-73 Volvo front were perfect for a 1 inch drop and firm ride.
    If you can find a larger front sway bar that fits, this will help also but I have no idea what would fit as Buick, Olds, Pontiac & Cadillac were all slightly different. Go figure.
    Keep us posted!
    Algoma56 likes this.
  8. partsdawg
    partsdawg
    from Minnesota
    Healy Spring in Minneapolis has been around a long time. Might have a answer.
