Does anyone have a Dorman or similar number for a replacement Wheel Stud that would fit a 40 Ford Hub? I would ideally prefer a longer stud as this is for a Bonneville Car, and I`ll have to use a 1'' Lug Nut....Thanks in Advance....KP...
MT car products sells a stud for their replacement brake drum. The hole has to be enlarged to 0.600 and the stud is slightly longer about 1/4". These studs are press in style for a removable drum with the hub inside the drum.
