Hot Rods Replacing a 1934 steering column - with what?
Discussion in 'The Hokey Ass Message Board' started by steve hackel, Feb 14, 2016.
  1. steve hackel
    steve hackel
    Is there anything out there that is compatible with a stock 1934 steering column/box - possibly a 1953/56 F100 or something similar in size? Later steering would obviously be better and also easier to obtain parts for a rebuild, so has anyone found a replacement that would work in an otherwise stock type setting? Thanks
  2. Rocky
    Rocky
    Classified Editor
    I'm using a 40 ford column and switch on a vega box. Haven't got it in the car yet.
  3. 32 Barn Car
    32 Barn Car
    from Oregon
    This is my 40 - 47 Ford Pick Up column & 40 standard wheel using the stock 32 column drop / switch with a vega box in my 32 , should also work for a 34.....
  4. 55willys
    55willys
  5. steve hackel
    steve hackel
    To those that have used the Vega steering box, did you convert to a cross steer drag link or somehow modify something to work with an original style drag link? What were the issues with mounting the box - good & bad - and what did you do for the steering column connection. Thanks
  6. Jeep. As in Willys Overland jeep. They are repoped or you can still find them, simple columns and they work real well. They didn't change them from the war until the redesign in the mid '60s
    Here's a ****py pic of a '62 they plug right into the steering box like an old Ford.
