Technical Replacing a riveted fuel pump diaphragm?
Discussion in 'The Hokey Ass Message Board' started by Hemi Joel, Jun 17, 2021.
  1. Hemi Joel
    Hemi Joel
    from Minnesota
    16239409370287658718298160954062.jpg Hi, I need to replace the fuel pump diaphragm on a 57 DeSoto. I have a sheet of reinforced Buna n rubber membrane that I have cut several diaphragms out of for other cars. On all the fuel pumps I have down in the past, the two plates that the diaphragm is sandwiched between are bolted together with a single nut and bolt through the center, with the bolt being attached to one end of the actuator arm. When I took apart the DeSoto fuel pump, which was clearly an aftermarket replacement, I found that instead of a nut and bolt, it is riveted to the actuator arm with a single rivet through the center that goes through the bottom steel disk, the diaphragm, and the top steel disc.
    Has anyone drilled out or ground off a rivet on a fuel pump like this? How did you get it back together? Drill and tap for a bolt? Put in a pop rivet? Before I possibly screw this thing up, I'm looking for the voice of experience. Nobody that I know of has a new pump available.
    Thanks, Joel
    winr likes this.
  2. harpo1313
    harpo1313
    from wareham,ma
    If you bolt it back together use nyloc nuts, stainless bolts.
  3. bigdog
    bigdog
    In the past I've drilled out the rivet and put it back together with a bolt.
  4. Dan_IN_MN
    Dan_IN_MN
    Joel
    Were you able to repair the diaphragm for the fuel pump? The fuel pump for my 1958 Plymouth Suburban with a 318 Polyester has a leaking diaphragm. I got a replacement, which is for the 318 LA, which pumps fuel just fine. However, it doesn't allow me to use the hard line from the pump to the carburator.
    I'd like to replace the diaphragm material in my old pump.
    Thank you!
    Desoto291Hemi likes this.
  5. Hemi Joel
    Hemi Joel
    from Minnesota
    Dan, I did not end up fixing it. I found RockAuto had a replacement. They listed it as the last one so I snagged it. It doesn't look exactly like the one I took off, which I suppose doesn't matter anyway because it was an aftermarket pump that I took off. But it did fit right.
    Dan_IN_MN likes this.
  6. Dan_IN_MN
    Dan_IN_MN
    Joel
    Thank you for getting back to me!! Much appreciated! I joined this forum just to ask you this question! LoL
    I take it the diaphragm you got had the plate riveted on it so you didn't have to go through all of that.
    Do you remember the thickness of the material? I'm seeing .062" for diaphragm stock.
    I found some material 12"X 12" X .062" for around $10.00.
    I'm in SW MN. I plan on being at Henderson's cruise in sometime this summer.
    Regards,
    Dan
  7. Budget36
    Budget36
    So you’re telling us you have have a goldchainer streak running through you?
    ;). Messing with you.
    Still subbed to the trunk monkey thread. I’d suspect it won’t happen.
    Hemi Joel likes this.
