Hot Rods Replacing Ignition Switch Rack in a 1978 Olds Cutlass Tilt Steering Column
Discussion in 'The Hokey Ass Message Board' started by Bazz Fletcher, Feb 13, 2016.
  1. Bazz Fletcher
    Bazz Fletcher
    I have to replace Ignition Switch Rack in a 1978 Olds Cutl*** Tilt Steering Column fitted to a '47 Ford Coupe. I need advice as to whether this can be done in the car or does the column have to be removed? Also, can anyone tell me where I can purchase nylon bushes for the advance weights in a standard GM V8 HEI Distributor? GM have discontinued these. Any advice you can give me would be greatly appreciated. Thanks guys. Bazz from Australia.:(
  2. mgtstumpy
    mgtstumpy
    Try this business, there are others out there as well. Insofar as bushes are concerned I'd try an ignition shop over there. GMC Bubba is a HAMBER and might have them or know where to get them
  3. David Gersic
    David Gersic
    from DeKalb, IL
    There's a good guide to completely rebuilding the GM column, if you Google for it. That should show enough to decide whether the column has to come out, or you can do it in place.
  4. bobss396
    bobss396
  5. 325w
    325w
    The bushings were supplied in some of the aftermarket weights kits. Kits used to alter your advance.
  6. Bazz Fletcher
    Bazz Fletcher
    Thanks Mate - I have emailed GMC Bubba but haven't had a reply as yet.
  7. Bazz Fletcher
    Bazz Fletcher
    This was a great help - thanks. Have now got it sorted. the column stayed put.
    David Gersic likes this.
  8. Bazz Fletcher
    Bazz Fletcher
    Thanks for your advice - have fixed problem now.
  9. Bazz Fletcher
    Bazz Fletcher
    Thanks for your advice.
