1952-59 Ford Repop fuel tanks??
Discussion in 'Off Topic Hot Rods & Customs' started by DannyBastard79, Jul 3, 2010.
  1. DannyBastard79
    DannyBastard79
    from Austin, TX
    Does anybody make a poly fuel tank specifically for 52-54 cars??? I am pretty sure I need a new one and I'd rather get one that won't explode if I bottom out on the air ride. If anyone can point me towards a good company or source, that'd be awesome.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    I wish I had a link to refer you too but I'll give you a general idea what was done,measure the dimensions of your stock tank then check out your nearest Pic-A-Part and check out some of the later Broncos and SUV's that used a poly tank if you find one that is close you will cut out the trunk floor just enough to accomidate the new tank add about 3-4" of sheet metal around the the section you cut out so the new tank will be moved up higher for clearance,then refinish.
  3. junkyardjeff
    junkyardjeff
    If its the same as a 55 or 56 there is a company in Minnesota that also sells windows that is the cheapest so far,I will have to look up their info as I dont know where I put it.
  4. raceron1120
    raceron1120
    I think it's Toms Cl***ics in Minnesota but I dont' have his contact info readily available either. He sells a lot of stuff on ebay, his handle is tomscl***ic. I don't know if he has poly replacement tanks but I got my repop steel tank and several other pieces from him for my '56.
    His prices were best I could find.
    Ron
  5. Retro Jim
    Retro Jim
    I have a 55 Ford and got mine off Ebay . Good tank too .
    Jim
  6. Paul2748
    Paul2748
    Check ebay. Some guy advertises there all the time.
  7. raceron1120 is correct. You can find him on ebay or you can call him. His number is 1 800 828 2212
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. DannyBastard79
    DannyBastard79
    from Austin, TX
    Cool...thanks for the info, everyone! Too bad about the ethanol/poly tank thing...If I drop it with bags and the metal one hits the ground...game over. Looks like my only option will be a fuel cell, which screws up the trunk space and just plain ****s for a kustom.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    Well you could fab up a skid plate like the 4X4 guys use out of diamond plate.
  11. missysdad1
    missysdad1
    Danny: As little as I am into air ride systems, I think a fuel cell in the trunk is a forgiveable sin when it comes to safety vs. appearance.
    Many modern customs seem to go with the fuel cell option, so many that it almost seems normal in a well-engineered frame-layer.
    I will never understand the need to drop a car to the ground when you park it, but if that is what spins your prop, at least do it safely.
  12. DannyBastard79
    DannyBastard79
    from Austin, TX
    I don't wanna have it drop all the way to the ground...just going for a driveable tail-dragger. The roads in Texas aren't exactly the best. :0) Still worried about the tank bottoming out though. If I ever get around to building a 60's style car it'll lay frame, but not this one.
