Report from the...ahem...upholstery shop
Discussion in 'The Hokey Ass Message Board' started by Rolf, Aug 22, 2006.
  1. Rolf
    Rolf
    I replied earlier in the post, but here it is again:
    Somebody asked for the source of the pleated vinyl. I got this from Gary's Upholstery:
    http://www.garysupholstery.com/marine-vinyl.html
    Please note: On the sample picture on his web site, it looks like it does not have a heat seal seam, but it does.
    Most upholstery stores (marine and auto) can get it too.
    Also, about the sewing machine, yes, indeed, it is an industrial machine, I tested it in 1/4 inch thick leather. However, if I do this again, I would opt for a deeper throat (sounds like a movie I once...heard of...) , especially when you are sewing the heel pad in the carpet.
  2. haring
    haring
    Great job!
    Looks good to me. You are too modest.
  3. Looks great! I've only done upholstery that doesn't involve sewing (chair bottoms, benches and one conv. top) so I appreciate how much work is involved. I like doing it, cuz it's almost like instant gratification, one minute it's raw materials, springs, foam batting and vinyl, the next it looks like something.
    What brand and model is the sewing machine, so we can keep an eye out... A machine than can go through 4-5 thicknessess of vinyl. $120 sounds like a deal.
  4. sodas38
    sodas38
    $300, and it looks that good, your a sick sick man. I love it! Great job.
  5. Dirk35
    Dirk35
    Thats Beyond "Presentable"!!!!
    Thats F'N Awesome! Thansk for sharing. New we need to request to Tech Archive this when they all return from the Drags.
  6. skipstitch
    skipstitch
    Rolf... you sir are a ruler! And there's no "new car funk" in this seat at all :) :) :) I love it!!!!
  7. Rolf
    Rolf
    Coming from YOU...that means a lot...:)
    ...funny that you remember, some folks thought we were talking about the smell :D
  8. JohnnyP.
    JohnnyP.
    man, that looks real good. wish my shit turned out that nice.
  9. racer756
    racer756
    Rolf, just awesome!!
    Thanks for the sharing.
  10. starion88esir
    starion88esir
    Absolutely sick! You buy all your supplies at a local upholstry shop or online?
  11. AllSteel34
    AllSteel34
    First off, beautiful job, Rolf!
    I have a Mini Brute machine. It cost about $500. It's a decent import machine that will go through several layers of naugahyde and carpet in one pass.
    http://www.qualitysew.com/brute.html
    I also have a Juki LG-158 which is a long arm industrial machine (~29" throat depth). That one was a little more expensive ($2,000 used). However, I only use the Juki to do wide (>~36") rolled and pleated sections for seats since they fill up the small throat on the Mini Brute.
    I know doing your own upholstery seems intimidating. I bought my first machine and just played with it for a few years. I didn't get serious until I got a quote for $1800 and six weeks for the interior of my '49. So I decided it was time to go to the school of hard knocks. Yes, you will probably be unhappy with your first attempts. I sure was. But stick with it! With some practice you will get the results you want. I had to redo quite a bit before I felt it was acceptable. The nice thing is that unless you're starting out with leather, it's relatively cheap to screw up something, scrap it, and start over.
    Read everything you can about sewing to get the basics of seam construction and pattern layout. I highly recommend the following:
    Automotive Upholstery Handbook by Don Taylor
    How to Restore and Customize Auto Upholstery and Interiors (Motorbooks Workshop) by Dennis Parks
    My first job, '49 Chevy:
    My second job, '36 Ford:
    Chris
  12. Custom54
    Custom54
    Awsome Rolf, you have given me great tips for my interior. Thanks
  13. fatluckys
    fatluckys
    Nice job!! It looks better than a lot of stuff I've seen come out of actual upholstery shops! Good job on the sail panels- that's a trouble spot that a lot of people can't figure out.
  14. I would like to see how you did the seat. Rolf, this is fine!
  15. This is going in my tech file.
    Rolf's top insert & interior posts are going to come in handy someday.
    Great work!!
    JH
  16. JohnnyFastTruck
    JohnnyFastTruck
    You make it all look so easy! Thanks for sharing everything you've done!
  17. DeuceDog
    DeuceDog
    from Breese, IL
    Rolf,
    I didn't see this asked in the previous post and if I missed it I apolgize. How much of each type of material do you purchase/use? I was told I would need 5 yds for my seat alone:eek: . I noticed you didn't use any windlace. Any reason, or were you going to add it when you install the headliner?
    Thanks
    DeuceDog
  18. Dan
    Dan
    Awesome job, very nice and timely work as I am trying to tackle this right now on my '54. Couple of questions:
    what if anything did you use for insulation under the door panels?
    how are you cutting / putting holes in the black door panel material? everything I try looks like a beaver chewed it up...
    did you just wrap and glue the vinyl and pleated vinyl around the door panel? Do you wrap the corners or straight sections first?
    the door panel clips, did you put any kind of "backing" (to keep them from pulling out of the door panel???) between them and the door panel or just make a hole in the door panel and push the clip through
    thanks-
  19. zman
    zman
    from Garner, NC
    That things it tits..... awesome job as usual...
  20. Jeem
    Jeem
    Alliance Vendor
    More than a ruler, you're a yard stick!
    ...sorry, that was dumb.
  21. Appoligies I'f I'm wrong (but I don't think I am), can this thread be added to TECH please?
    Cheers,
    Drewfus:D
  22. Rolf
    Rolf
    Sorry Dan, I didn't see that this thread got life again...
    To answer your questions:
    None under the door panels, but on all metal surfaces I used the OEM style self adheasive "lead" mat, works great.
    Sorry about the beaver, Wally...ahem, I use hole punches.
    Yes, and straights first. Practice on a couple of leftover pieces, and you will get the hang of it.
    The clips clamps on the door panel thru the hole, as long as you use the right tool when removing them, you should be OK.
    Hope that helps.
    Rolf
  23. attitudor
    attitudor
    from Finland
    How about moving this thread to tech archieves?
  24. Oilcan Harry
    Oilcan Harry
    from INDY
    Rolf, you do great work! Yours is one of the few cars I can say I wouldn't change a thing on. That almost NEVER happens. If my project turns out half as nice as yours I will be thrilled.
    Would you have anymore info on your seat cover? I think I have a pretty good handle on the rest of the interior but the seat cover I don't have figured out yet. Your seat looks like a pro did it. U R amazing.
  25. Rice n Beans Garage
    Rice n Beans Garage
    Nice job, looks great, how do I get an appointment !!
  26. Model "Eh"
    Model "Eh"
    from Denver
    Assuming you're the same Rolf that used to live in Denver.. Congratulations! You were always one talented motherfucker. Oh, and by the way... fuck you for being such a talented motherfucker. Love you, bro.
    --Bob
  27. Rolf
    Rolf
    I heard this thread came alive again...
    Harry, I don't have any pictures of the seat work. Basically, I outlined the seat panels with a marker pen. Then I cut them right at the marker line.
    When I sewed them together, you loose about 1/4 to 1/2 inch all the way around, but that allowed for some stretch, and a wrinkle free installation.
    Hope that helps.
  28. Django
    Django
    from Chicago
    Did you ever get to the headliner?
  29. pan-dragger
    pan-dragger
    great tech, and it turned out nice too.
