Hot Rods Repro Scot blower can't make real boost
Discussion in 'The Hokey Ass Message Board' started by CheatersPete, Jul 24, 2018.
  1. brigrat
    brigrat
    from Wa.St.
    Well if you have an original to copy why not copy it rite down to the nats ***?????????????????
    19Eddy30 likes this.
  2. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    D9E4CFCC-DFFD-41C6-824A-6DCABB45D817.jpeg Joe Abbin of RoadRunner Eng in Albuquerque has a 335 dyno h.p. Flatmotor that runs a Isky 400 jr camshaft and modified cast iron Merc heads. He is an engineer,has a flow bench, and a dyno and knows how to use them. I think he runs 4-6 lbs boost,but not positive on that figure. I know he runs a B & M blower. Flatheads Forever!
    loudbang and 19Eddy30 like this.
  3. CheatersPete
    CheatersPete
    Here is the answer form HandH
    Peter,
    I have been in contact with Holley Corp. regarding your issue, since I purchase rotors from them, they will send
    me another spec sheet on the rotors.
    I will also do the math here on the CNC machine operations to double check measurements.
    Next week when I have all the calculations before me, I will evaluate the issue you are having.
    Since the SCOT Blowers are based on a specific CFM, I am sure this can be figured out, it seems to
    be a mechanical/physical issue.
    I have built and run over 200 blowers on Arduns, Flatheads, Dixon Headed Flatheads and some one off Buicks
    etc. and have not encountered a low boost issue, except 1 where he had a physical dimensional issue and could
    not fit the correct pulley size to a wide belt application he made.
    Thanks Max Sr.
    Hope they find a solution
  4. Kiwi 4d
    Kiwi 4d
    Hope it turns out for the best Cheaterspete.
    On our H&H scott we also had issues with the drive belts. My wife was enjoying a drive one day ,when she came home I noticed small bits of rubber on the ch***is . Seems the toothed belts do not like being bent backwards on the idler. We used the exact same belts as H&H .
    Tried numerous belts and eventually settled on an ugly pair of green Kevlar belts. We took advise from a belt drive spe******t. Don’t know how long they would have lasted as we took the blower off due to unsatisfactory boost.
    I know it would not look the best but would it be possible to fit pulleys to suit a serpentine belt??
    19Eddy30 and loudbang like this.
  5. HotRodMicky
    HotRodMicky
    Hmmmm , a lot of people seem to have problems making boost with the h&h blowers ...their pulleys should have a ratio to make boost at a certain displacement (cam aside)
    A roadrunner weiand kit always makesgood boost . Then adjust it once to your engine size and cam and it simply works ....a few around here
  6. Bandit Billy
    Bandit Billy
    To clarify, HandH SCoT blowers are the only ones I heard mentioned. I have their 471 and no issues making 7 pounds out of the box.
  7. HotRodMicky
    HotRodMicky
  8. HotRodMicky
    HotRodMicky
    I have a second hand set 4-71 . 12psi
    Fun :)
  9. brigrat
    brigrat
    from Wa.St.
    Some one must have invented a "flow" bench machine that you would tell the out put versa the input or boost? Kinda like a head flow mach? If so and they are independent of H&H that's were I would send it. 7G's is a little much for a blower that's just a poser at the moment. All of this is of course ***uming everything else is up to snuff ........................................
    loudbang and Unkl Ian like this.
  10. Unkl Ian
    Unkl Ian
    The big NHRA teams have blower dynos.
    I imagine the serious racing blower companies like BDS would have one.
  11. Fordors
    Fordors
    CheatersPete, did you get a chance to check the rotor to case clearances?
    gimpyshotrods likes this.
  12. CheatersPete
    CheatersPete
    7000 is a lot for a non working hair dryer... I agree... My engine is making 125hp to the wheels, I have the dyno chart.
    The blower is the issue there, Now I m waiting for a solution from HandH. I had no time to check rotor clearance but will do it asap.
    loudbang and WiredSpider like this.
  13. Bandit Billy
    Bandit Billy
    I hope that wasn't headed my direction. I've already had to s****e off rubber from my tail pipes and quarter panels and I only have 70 miles on the flatty. :cool:
  14. brigrat
    brigrat
    from Wa.St.
    You have a 471, Apples & Oranges!
  15. Montana1
    Montana1
    BDS says to use a 110* LSA on all their blowers on different motors. It doesn't specifically show a flathead, but the ***umption is... Look at this chart.
    http://www.blowerdriveservice.com/blower-cam-specs.html
  16. gimpyshotrods
    gimpyshotrods
    One size does not fit all.
    Physics does not back this.
  17. Montana1
    Montana1
    OMG, somebody ought to tell BDS about this! But then, Physics doesn't know if it says Ford or Chevy on the hood.
  18. gimpyshotrods
    gimpyshotrods
    You just don't get it. I will explain it to you, when my plane lands.
  19. Montana1
    Montana1
    I get it... but then, some things just don't matter and this is one of them.
  20. Harv
    Harv
    from Sydney
    Agree with gimpyshotrods. LSA is a simple number... it needs duration and profile added to it before you can determine overlap (it is the overlap, not the LSA, that blows boost out the exhaust). As an example, Lunati specify various LSAs for their SBC blower cams, ranging from 110-114º. A single LSA probably makes cam stock management easier for BDS.
    Cheers,
    Harv
    mad mikey and gimpyshotrods like this.
  21. gimpyshotrods
    gimpyshotrods
    No you don't, and yes, it does.
    The suggestion that a single LSA (and by definition overlap) is appropriate for all engines, regardless of engine design, cam profile, and intended use is intellectually dishonest and lazy.
    Proper cam selection needs to take into account every single aspect of the engine's design, from displacement, to rod/crank ratio, to cam lobe profile, to intake and exhaust runner specifications, valve sizes, combustion chamber shape, piston dome/dish shape, head material, to intake design, and dozens of other variables.
    One LSA will absolutely not work properly on every engine, in every use-case.
    One thing that will not vary is the fact that the wider the LSA, given all else equal, and an identical cam lobe profile, the more useful boost will be made (until the point of diminishing returns is reached). This is basic physics. Remember, they are not called The Friendly Suggestions of Physics, they are the law.
    So why do companies make blanket recommendations like BDS does?
    Companies like BDS, Weiand, Holley, etc. are in the business of producing supercharger kits that the average Joe can bolt on, produce moderate performance gains, without the risk of destroying their engine. They have to do this. If they don't leave a substantial amount of potential performance on-the-table, there will be a decidedly increased risk of a catastrophic failure. While likely not to be the fault of the manufacturer, the manufacturer will nonetheless be blamed.
    In the age of instant communication, it is VERY easy for a company to earn a poor reputation, and lose some, if not all of their business.
    How do I know this to be true? I am a Senior Engineer at the world's 5th largest automaker. It is literally exactly my job to explain conditions like this to folks like Senior Executives, all the way down to line-workers, and to see to it that they do not happen. When you are sitting on $220,000,000,000.00 in ***ets, and produce almost 10,000,000 vehicles per-year, you can quickly become a target for litigation, if you even slightly slip. A company like BDS could be erased from the face-of-the-earth by serial litigation, even if they did not lose, just from reputation damage alone.
    I have personally watched guys at Sonoma Raceway swap upper and lower pulleys (going from underdrive to overdrive), on what appear to be otherwise stock SBC's, but with blowers. On more than one occasion, the result was a rod, or rods, right out of the block, on the first p***. Each said “something wrong with the blower”, or something to that effect. This could end up being a retailer's worst nightmare.
    That performance left on-the-table can be the difference between a powerful engine, and one with 50% more power, with almost the same (in design, and cost) hardware (if it is built right in the first place).
    Real horsepower is built, not bought.
    I can personally guarantee that if I took the 115º LSA cam out of my purpose-built to be blown Hemi, and put in an identical grind, except at 110º LSA, I would lose 150 to 175hp, or more.
    Building generic, formulaic kits for the public, for engines of unknown quality, is not the same thing as building a specific engine, for maximum power and durability.
    I know guys that have girdled stock-block Honda 4-cylinders, producing over 1000hp, at the crank.
    Nobody sells that as a kit.
    Why? Because ever slack-jawed yokel with a credit card would blow up their poorly built engine, in the first 5-minutes.
    Pat, mad mikey, dwollam and 9 others like this.
  22. Montana1
    Montana1
    Gimpy, maybe I need to clarify this a little. I'm NOT in disagreement with you on overlap and LSA. CheatersPete is only looking for the reason why he has less boost with a smaller blower.
    I recommended a 110* LSA using BDS as my reference for street blowers. CheatersPete is not looking to make 1000 HP flathead. He's just wondering where a couple of pounds of boost went.
    Come to find out his cam choice uses a 108* LSA. A 110* LSA is a step in the right direction. Speeding up the blower is another step in the right direction. I personally think he needs another carb on top, but that's another story.
    BTW, thanks for your technical input. Next time, please don't jump to conclusions that don't matter. He doesn't need a 115* LSA (or a 6-71) for only 4-7 lbs. of boost. The thing will have NO rumpity-rump that every self respecting hot rodder wants to hear. ;)
  23. CheatersPete
    CheatersPete
    Hello, Just checked the clearance, I have 0.015 between the lobes and 0.011 between case and lobes...
    Dyers said that I should have 0.008 between rotors and case, but it should give more boost... waiting for HandH answer..
  24. x77matt
    x77matt
    Hi Pete- I'm following along with interest. I was wondering if you have done any additional research about your cam and if it is a known good grind for a blower, or if it has too much overlap to take advantage of what the Scot has to offer. I keep thinking a rotor quality issue is less likely than perhaps a wrong cam pick, but that is only non-fact based opinion ....
  25. Kiwi 4d
    Kiwi 4d
    We had the same very low boost issue and we were running a tame Max 1 cam in a very carefully built and basically blueprinted flathead. The blower seemed to get in the way of the intake charge. Waiting patiently to hear Peters outcome.
    X38 likes this.
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
  27. CheatersPete
    CheatersPete
    My turn to jump on this:
    No i do not have the perfect cam for blower application and I will now purchase another one with the specification below
    Intake Duration (gross): 280
    Exhaust Duration (gross): 270
    Intake Duration (.050”): 242
    Exhaust Duration (.050”): 234
    Intake Valve Lift*: .375"
    Exhaust Valve Lift*: .365"
    Lobe Separation: 112
    + I just swaped my carbs for the new stromberg 250cfm. I use to have the Holley 94 rated at 165cfm.
    Will have to tune and let you know.
    thanks again for all you positive ***istance on this
    Best regards
    Pete
    soonrodder, Johnny Gee and Montana1 like this.
  28. x77matt
    x77matt
    Awesome Pete - can't wait to hear the result! Also I have been wondering about the new 250cfm strombergs and if they open up more power opportunity.
  29. HotRodMicky
    HotRodMicky
    Your new cam must have less overlap to make more boost at low rpm than the L-100 cam .
    Is this the case ?
    I really dont think your problem is camshaft related ......
    If so , i would go smaller on the cam not bigger.
    Didnt make really good power years ago with
    A 4-71 blower and a Max-1 cam?
    Bigger carbs are a good Idea .
    Anyways , its cool that you try to find the boost and not just leave it alone.
  30. Unkl Ian
    Unkl Ian
    Sounds generous.
    Stueeee likes this.
