Projects Reproduction 392 Hemi block
Discussion in 'The Hokey Ass Message Board' started by Maroon Goon, Oct 5, 2016.
  1. I'm probably shooting myself in the foot here because I want to put an early Hemi in my FED. Bear Block Motors is reproducing 392 Hemi blocks. I'm not an agent for them and have no experience with their products. Just p***ing on some info I found while searching for early hemi parts. They already sell Ford side oiler blocks and heads so maybe I'm posting old information. They are in Chatsworth CA and sold the first batch and have one block left at $4200 plus shipping. Next batch is expected in late November. I contacted Doug at info@bearblockmotors.com and their website is http://bearblockmotors.com/ . Sorry the links didn't work.
    Regards,
    Roy
  2. dreracecar
    dreracecar
    from so-cal
    from the looks they are a real nice piece---- however I did hear of one block having an issue with oil in the water jacket, Could be a machineing or casting issue for just that one block, so make sure they pressure test it before you buy
  3. broke hotrodder
    broke hotrodder
    from NY
    Decent original blocks can be found for $600- $800, decent heads for half that and a nice crank for $800. With mild machining you will be ahead and have the real Mcoy. Unless it will compe***ive, I think it is better to go with a used seasoned block. Spend the money on upgrades and machining. My two cents.
    gimpyshotrods and HiHelix like this.
  4. 73RR
    73RR
    There are still some oem blocks 'out-there'. No, not cheap but certainly not $4200.
    All depends on the needs and the funds. If you are running the FED hard then the extra cost may not be a bad thing.
  5. gimpyshotrods
    gimpyshotrods
    I can still find OEM 392's. The last one that I sourced for a customer, stock bore, stock deck, was $600.
  6. 73RR
    73RR
    Excellent price!!
  7. gimpyshotrods
    gimpyshotrods
    I also recently scored two stock bore, uncut crank, 354's, for $1400.
