Customs Repurposed Appliance Louvers
Discussion in 'The Hokey Ass Message Board' started by BOOT77, Aug 13, 2023.
  1. BOOT77
    BOOT77
    from Michigan
    Was s****ping an old Maytag dryer and had the idea to save the rear panel with louvers to use as some hood vents. Found more on ebay, Maytag Dryer Rear Access Panel part number Y312951 or 312951. They are steel, so welding is an option for the right flat-ish panel. Hope it helps some custom Hot Rodders create something cool!
    Made a quick vid for any interested just check out my signature for the channel link
  2. 19Fordy
    19Fordy
    Great idea if you can find enough matching pairs. Do you think the heat generated when
    welding them in your hood is going to create too much distortion?
  3. BOOT77
    BOOT77
    from Michigan
    They are kinda thick compared to modern body panels. Just measured a couple in a few places .035 at the thinnest, .040 thickest.
    Also forgot to mention the entire back panel had more louver sections(diff sizes) but they'd have to be cut off.
    lothiandon1940 likes this.
  4. 31Apickup
    31Apickup
  5. BOOT77
    BOOT77
    from Michigan
    Just figured some might even want em for a ratrod and they can be found free on the side of the road LOL
  6. 19Fordy
    19Fordy
    On second thought, louvres are too wide.
    Better to go with traditional style and size.
    Plus better results and lower cost would probably be obtained by punching the hood.
  7. lothiandon1940
    lothiandon1940
    Have a look at any s****ped, "pusher" style school buses. The rear panels over the engine are full of louvers.
    Just Gary and BOOT77 like this.
  8. 31Apickup
    31Apickup
    I got mine out of a s**** pile at an estate sale, cut it down to the size I needed. It looked to be off of a equipment case of some sort.
    BOOT77 likes this.
  9. rusty valley
    rusty valley
    I never have understood why guys want to poke a bunch of holes in their cars. Just me,...the old grouch...carry on
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
    Putting appliance parts on my rods...I don't know if I would like the Maytag Repairman just popping up in the rear view mirror or being found curled up in the trunk.
  11. williebill
    williebill
    Maybe useful on inner fender panels to vent under the hood, but on the body?
    Bob Lowry likes this.
  12. BOOT77
    BOOT77
    from Michigan
    You know what they say, when in Rome....
  13. catdad49
    catdad49
    Bucket Louvers.JPG Bucket Front.JPG This is the last version of my old T bucket. The louvers I used to create these parts were originally a large piece of house gable venting that I found in the attic, complete with multiple layers of house paint. I had to strip these, carefully, to avoid lead poisoning (house built in '42). The front cover piece was the most difficult because of the bending, but worked out OK. Reuse in Rodding!!
  14. stanlow69
    stanlow69
    Back in the 80`s while going thru Chicago on the interstate in stop and go traffic during the summer. Dad`s flathead got hot. He had louvers punched in the hood. The next 35 years it never got hot again.
  15. bobss396
    bobss396
    Really not a bad idea. I have seen a lot of louvers that have varied quite a bit.
    There was one well-known model car builder, he made his own louvers from thin aluminum stock and grafted them onto hoods and trunks, very well done and blended right in like they grew there.
    BOOT77 likes this.
  16. lothiandon1940
    lothiandon1940
    I'm a lover of louvers. To me they just scream........Hot Rod.:) thumbnail (14).jpg 345605112_771672901130195_1555512600617747556_n.jpg 60548225_2319268048118693_1876908138645422080_n.jpg 20160823_184325 (1).jpg
  17. dirt car
    dirt car
    from nebraska
    Not for every project but on the right type of vehicle a bit of military looking rivet work lends an industrial no nonsense business at***ude without the welding, warping issues.
  18. In_The_Pink
    In_The_Pink
    Vintage lockers are another source, but the doors are usually very thick-- maybe too thick to match up with a vehicle's sheet metal. Older central air type A/C units usually have plenty of louvers, too:
    Vintage space heaters...the list goes on. Basically anything pre-'70 made of metal, designed to heat, cool, or ventilate.
  19. goldmountain
    goldmountain
    I just happen to have a junked dryer that I kept for sheet metal to make patch panels from and measured the louvers. 6" wide. Don't think they will work. The only way to get good louvers is to get them punched by someone with a louver press made specially for our cars.
    dana barlow likes this.
  20. BOOT77
    BOOT77
    from Michigan
    Forgot to mention for my use they will deff be trimmed up some and I'll drill holes for rivets. I'm not a body guy, just thought cause they were steel and a decent gauge ,they might be welded on for the right app.
  21. Budget36
    Budget36
    I’d guess they would be good on hood sides and other flat panels
    I wonder how trying to make them conform to a curve area would work?
  22. BOOT77
    BOOT77
    from Michigan
    As you installed them(rivets/screws) they'd bend a bit and some you'd have to maybe prebend them but I doubt you'd be able to much. Welding you'd deff have to push with like a handle n tach n then position again tach n so on...
    I mocked them up on my 09 truck hood in the vid But I know some of the older cars have flat-ish panels. Also I own some other more expensive larger vents/louvers and they are flat and meant for slightly curved hoods.
    Budget36 likes this.
  23. Finished T1a.jpg A buddy of mine had some old electrical cabinet doors, that he used for hood sides. He lucked out, and the space between the rows of louvers was enough to cut a slot for the header tubes to come out. No welding just cutting, and breaking an edge top and bottom for hood, and lower mount flange.
    Budget36 and BOOT77 like this.
  24. A Boner
    A Boner
    High school locker door louvers would be very traditional!
    bobss396 and BOOT77 like this.
  25. swade41
    swade41
    from Buffalo,NY
    These are 5 inchers from a big utility truck box I found in the junkyard, heavy, like 35-40 pounds a panel.
    In_The_Pink, BOOT77 and Budget36 like this.
  26. In_The_Pink
    In_The_Pink
    Stepped outside and took a few pics of my Rheem A/C unit from 2009 or so. A bit too wide and too close together compared to traditional louvers, but they could be useful.
    BOOT77 likes this.
  27. Mo rust
    Mo rust
    Didn't corvair's have some interesting louvers on their decklids? That might be an interesting option.
    BOOT77 likes this.
  28. mr.chevrolet
    mr.chevrolet
    locker louvers cut in and smoothed. No, i didn't do it. CIMG3841.JPG Aatshop6.JPG A-11.jpg
    BOOT77 and In_The_Pink like this.
  29. In_The_Pink
    In_The_Pink
    Yes, they did. :D
    jnaki and BOOT77 like this.
  30. BOOT77
    BOOT77
    from Michigan
