Reputable Rearend Shop
Discussion in 'The Hokey Ass Message Board' started by Trucked Up, May 14, 2012.
  1. Trucked Up
    Trucked Up
    Looking for a shop within 2-3 hours from me (Pikeville Kentucky in the far far far eastern tip of Kentucky) that can narrow a rerend I have in a 52 Panel Truck. Will also change the gear while I'm at it.
    Its a GM disc brake rearend. I have it installed in a finished vehicle and have a lot of money in it so I would like to have it shortened about 1-2 inches per side. Just trying to get a little less backspacing on my wheels.
  2. mustang6147
    mustang6147
    from Kent, Ohio
    There is a shop in Cinci, he does them I think.... I cant remember the name... Its a hotrod shop....I will post if I can find it...
    I will add most 4x4 shops do this as well.
  3. badshifter
    badshifter
    Call this guy: Steve Decker 502 468-0584 He'll either be able to, or will know who to send it to.
  4. SniffnPaint
    SniffnPaint
    Pete-o's in Akron. Ill find the number for ya.
  5. Deuce Roadster
    Deuce Roadster
    Moser Engineering is in Portland Indiana ... about maybe 300 miles ???
    Very well known rear end folks ... and reasonable on the money also. :D
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Last 3 sets of axles I ordered from them,,,, 2 of them I have had to cut to get them to fit. Last night we went to install a pair of custom axles from them. 12 bolt 30 spline center with big bearing Ford rear ends, p***enger side slid right in, drivers side needs to be cut 7/8". Double checked our specs, dead on. I would suggest NOT using Moser.
  7. BillWallace
    BillWallace
    "Maranatha car crafting" Spencer In. ph#812 829 2176. 30 miles s/w of Indy. Jeff Carlson can do anything rear end wise. It would be worth the trip!
  8. I am way off from Kentucky or I would offer to do the job for ya.
    Something to think about is that you will need to shorten the axles and those axles are probably stepped and won't shorten. So while you are buying new axles you should consider a C-Clip eliminator kit.
    Something else to think about is that the whole rear will need to come out of the truck to do the job and you can save a little if you pull it out yourself and just deliver the rear end to whomever.
