I'm trying to identify the application of this flathead Ford generator pulley. The part number is 40 10130 (maybe a CR suffix?). Diameter is about 3.18" and it fits a 19/32" (.593") shaft. I looked in the Ford green book on pages 458-459 and see a couple pulleys of this diameter, but not with the 40 prefix. Pages 468 - 469 list the various 10130 series pulleys, but none with the 40 prefix. I rebuild 6v generators on the side and am trying to get a few more ready for Hershey. If I know the application, I may build a generator for it. Thanks. Steve
I have seen a pulley like that on 32 Fords, but not sure if they were stock or what the part number was.
Ford garage's generator id chart shows generator 40-10000-b including part number 40-10130-b. https://www.fordgarage.com/pages/generatorchart.htm
Not a typo. The diameter is about 3.18" . Diameter at the base if the V is 2". Someone elsewhere said he found this pulley number with CR suffix in a Canadian Ford parts book with the note that it was used for obtaining normal charging rates at low driving speeds. So maybe its a Canadian part? Maybe a special order item? Just FYI, I restore flathead generators and refurbish original cutouts. So if I can identify a solid application, I'll build a generator with it. For some reason I'm not receving notification of replys here. I did check the box to get them. But I'll check back. Thanks Steve
