I have an old stick shifter rubber boot that is getting a little stiff and faded. Is there anyway to breath some new life into this thing? I heard silicone dressings just makes it shiny and slippery but will not make it softer or black again. Someone recommended soaking it in trans fluid for a few days..
Lestoil, it's an old household cleaner. Test it on something else. I softened a pair of floor mats about 4 years ago, and they are still perfect. Soak a day and check, soak a day and check, etc.
Would that be good for wing vent rubber too? Not able to soak, but apply as a dressing. Hoping for something to keep them from getting to where they need replaced............. Thanks!
I use a product called Wurth Rubber Care. Google it for a dealer near you, I promise you'll love it! There's nothing like it anywhere. It ain't cheap, but it works!
Don't let Lestoil touch paint. I've used it as an dressing but be careful it will strip paint. Don't let it soak too long or your rubber will be 4 times too big! Powerful stuff.
When I was in highschool me and my buddy first I used it then he turned it inside out and he used it. Also works for socks. There are a lot of products to choose from anymore and I'm not familiar with nearly all of them. But before there were all the new products to choose from we used vasoline. It wouldn't restore rubber that was cracked but it worked well on old stiff rubber products.
You and your buddy used KY? WTF porky? Oh, I've used Gibbs on rubber weatherstrip...made it nice and pliable again.
I usually take a terry cloth and scrub rubber pieces with Laquer thinner. It scrubs the hard crust off of rubber, and makes it look like new. I have also saved a couple 70's rubber steering wheels that way.
Sorry Tex I've been up most of the night, I forgot it was a little early in the day for that ****. How ya been anyway? Things poppin' for ya? You going to come up to MOKAN this year? Lets throw down a shot and grab a burger.
For rubber that's still pliable, but faded...I've used cheapo black spray paint. Once it get's tacky, use your fingers to grip it and knock the shine off. It makes old rubber (especially items like hood bumbers, door seals, trunk seals, etc) look new.
I have a pair of those white rubber mukluk type boots with cloth tops. They're so old the rubber began to check and flake off. I used Shoe Goo and smeared it all over with my fingers. It dried clear and hard, but flexible. The boot was stiffer than before but looks like new. I just wish I cleaned them better first. Now the dirt is under the clear. All those 'Goos' , auto, shoe, household, are the same thing in different tubes.
Yep, did the trick. Put the old shifter boot in a can of ATF for a few weeks, took it out and washed it with dishsoap. Restored most of the flexibility and even retored the black color. Thanks for the tip...
Here's what I use. 50% Gylcerin and 50% liquid soap. I've use this for years on Weatherstrips to keep them soft or to bring back old crusty ones. The good thing is you can wash it off if your going to mask the rubber parts later. A trick from my father that use to fly rubber powered model airplanes. They uses this mix to lubricate the rubber bands and make them soft. The Old Tinbasher.
Another product made just for what you want to do is Trim Re-Nu by AutoTech. No silicone,no gloss,works great. 800-545-8624.
