Hot Rods resurface flat tappets
Discussion in 'The Hokey Ass Message Board' started by RmK57, Feb 25, 2022.
  1. RmK57
    RmK57
    Looking to get a set of used Johnson solid tappets done rather than use the off-shore Comp Cams lifters that my new cam came with. Anybody have experience or results both good or bad with getting this procedure done?
    There is only one place in town that has the machine to do this so I'm thinking of giving them a shot.
  2. junkman8888
    junkman8888
    Many years ago had the cam and lifters reground for an off-thread four-banger as new parts were extremely difficult to find at the time, came out great.
  3. RmK57
    RmK57
    Ive watched a couple YouTube videos on it. Very specialized piece of equipment to get the right crown and taper on the face of the tappet. Not much call for it nowadays as most everything is roller or unfortunately thrown away.
  4. Wanderlust
    Wanderlust
    Had my lifters and rocker arm surfaced for the y block, 6000 miles and all’s well
    guthriesmith likes this.
  5. saltracer219
    saltracer219
    Oregon Cam Grinders can do this for you, 360-256-7985 ask for Ken.
  6. oldiron 440
    oldiron 440
    I thought I would see a bunch of negative comments on this but I like the idea. I just have a question about lifter and cam hardness because of new cam and season lifters, will they wear they same?
  7. Rickybop
    Rickybop
    I wondered the same thing. Do the people who regrind the cams and lifters also reharden the wear surfaces?
  8. 73RR
    73RR
    'Good' lifters are through hardened, not surface hardened so no issues with resurfacing.
    ...wondering what the OP's application is....
  9. banjorear
    banjorear
    Cam grinder Pete on here can do them for you. If the shop has the right tools to resurface with the correct radius then you should have no issue having this done.
    lake_harley and sidevalve8ba like this.
  10. Ebbsspeed
    Ebbsspeed
  11. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Have done hundreds vilas machine shop,Bryan,Texas —-comes back looking nice just a small crown cutting from the outside toward the center—-makes the lifter spin!!
  12. VI Lonewolf
    VI Lonewolf
    Shadbolt is apparently retiring. I'm having a cam ground and lifters re-faced by a guy in Salmon Arm thru a bud that has just retired from Lordco. Don't blame you on the Comp lifters. Mine had maybe 40 minutes of run time when I decided I didn't like the cam. Blessing in disguise.
    mgtstumpy and milwscruffy like this.
  13. hepme
    hepme
    Like the others said, I had a set reworked years ago and they came out fine.
  14. jimmy six
    jimmy six
    Egge lists they do it. I did a set on a surface grinder in my dads machine shop for my mothers 55 Olds. My dad taught me how. We didn’t need longer push rods either. I took every lifter apart and cleaned them up also.
  15. RmK57
    RmK57
    I called Shadbolt cams on Thursday and the owner or new owner said he'd be in Monday and to bring them by. Dont have bucks to go roller or tool steel tappets either so I'm giving this a shot.
  16. lake_harley
    lake_harley
    Who is "cam grinder Pete" and how can he be reached?
    Lynn
  17. Fordors
    Fordors
    @Pete1
  18. I had a FE Ford set refaced years ago (a very lo-buck build) and had zero issues with them. It was something like .50 each at the time... LOL.
  19. miker98038
    miker98038
    Over at yblocksforever Cliff has a grinder and has been checking hardness on various lifters.
    the link goes to the hardness test, the next page has a link to the grinder he bought.
    Not necessarily relevant to the OP, but a bit of education for those like me who knew very little about the process and testing.
    http://forums.y-blocksforever.com/Topic159972-1.aspx
    Elcohaulic likes this.
  20. RmK57
    RmK57
    .50 cents! The shop is going to charge me $6.00 a tappet, so around $100. If it works out, which it should, it's money well spent.
    Valve lift on this is around .590/.640.
    jimmy six likes this.
  21. .50 each in 1967 would be about $70 per set now accounting for inflation, so the price hasn't gone up too much... LOLOL
  22. motion guru
    motion guru
    from yacolt, wa
    Yes, Oregon Cam Grinders (in Vancouver) have done many a cam and lifter sets for me for inline GMC engines . . . they have good equipment and the competence to run it correctly producing good results.
    saltracer219 likes this.
  23. Beanscoot
    Beanscoot
    I had a set done at Shadbolt's in your fair city a couple decades ago for a friend's car, so far as I know it worked out well.
  24. akoutlaw
    akoutlaw
    Several years ago I had Delta Camshaft in Tacoma resurface a couple sets of flathead lifters. They did a great job.
  25. Fortunateson
    Fortunateson
    I had my original Johnson lifters and a cam ground to an Isky Max1 profile last year at Shadbolts off of Burrard and 6th I believe. They’ve been around since the mid ‘50s. Sometimes hard to get a hold off so if you have difficulties PM me.
  26. 55willys
    55willys
    Delta Cam in Tacoma has done many cam and lifter regrinds and they all come out great. Never had a problem with any of their stuff.
    akoutlaw and Hillbilly Werewolf like this.
  27. Truckedup
    Truckedup
  28. motion guru
    motion guru
    from yacolt, wa
    I have had two cams done by Delta in Tacoma damage lifters when improperly ground which is why I switched to Oregon Cam Grinders.
    The difference in valvetrain audible operation, lifter rotation consistency, and number of miles between required valve lash adjustments is significant with the Oregon Cam running quieter, all lifters spinning equally well, and valve lash adjustments needed less than once every 10k miles rather than once every 1000 miles.
    These are inline six cams and all run with ZDDP oil additives with proper break-in procedure.
    Truckedup likes this.
  29. RmK57
    RmK57
    Thanks! I appciate that. I called on Thursday and it didn't sound like he was at work. Mentioned something about Covid and he will be in on Monday.
    My cam is custom ground from Delta cams in Tacoma. Operator said it was ground off a Comp Cams Extreme Energy profile.
    I got Comp Cams solids with it and never felt comfortable using them, so I'm going this route. Should work out fine.
  30. 55blacktie
    55blacktie
    If you start with quality lifters that have never been resurfaced, go with someone who knows what he's doing. I second Oregon Cams, if they will do it. Ken is a great guy. I know they do Ford Y-block mushroom lifters, but I don't know about others.
