Return fuel line necessary?
Discussion in 'The Hokey Ass Message Board' started by Terrible Tom, Apr 26, 2012.
  1. Terrible Tom
    Terrible Tom
    I'm installing a new gas tank, the old one was too small. The old one had a return line from the mechanical fuel pump but the new tank has no provision for a return. Is it o.k to just put a plug in the return line fitting and run just the supply line? I am running a Holley 4bbl. and mechanical pump. Vapor lock doesn't seem to be a problem. Any advice is appreciated.
    Thanks, Tom
  2. Check the fuel pressure with it and without.
    I'd guess the pressure at the carb inlet will be higher
  3. tommy
    tommy
    I've never put a return line on any of my horods.
  4. dgang26
    dgang26
    I've never had a return line either
  5. derpr
    derpr
    double dat. check your fuel pressure. I run a tri-power set up, and to increase the fuel pressure. I pinched down on the return line. You didn't say what type of engine your runnin. earlier stuff I don't think have return lines. While the later stuff will.
  6. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    You don't need it with a mechanical pump. Mechanical pumps supply fuel based on RPM, and so long as you're not running a big hipo mechanical pump, you're fine without a return.
    Edit: Keep in mind that the pump doesn't create pressure, resistance to flow does. As derpr stated, decreasing the size of your fuel lines will often increase pressure, but it can also decrease flow volume. Both are important in your fuel system. You can have adequate pressure, but not flow enough fuel. You can have adequate flow, but not enough pressure. both will lead to fuel starvation issues. Standard rule of thumb for street setups is 3/8" fuel line, and 1/4" return, if you run one. Mechanical pumps are designed to provide a certain pressure through a certain size fuel line (again, usually 3/8"), but knowing your fuel pressure is also important, especially as a gauge of pump health and possible blockages in the fuel system. You can tell a lot of things by reading the pressures inside your engine.
  7. Terrible Tom
    Terrible Tom
    Thanks for the helpful answers. I forgot to mention that I am running 3/8" line and the engine is a 305 Chevy. Maybe I'll plug the return and see how it works.
    Tom
  8. derpr
    derpr
    a 305 would be a later smog model engine. you could get a fuel pump off an late 60's early 70's 327 or 350 and it will not have a return line.
