Reverse Flow Flatheads. .
Discussion in 'The Hokey Ass Message Board' started by zilly, Oct 6, 2008.
  1. zilly
    zilly
    Ok so guys what do you know about reverse flow flatheads.
    I have seen a few pictures nocking around that have intrested me and Id love to find out more. Can any one shead some light on the beasts?
  2. A Chopped Coupe
    A Chopped Coupe
    Here is an article briefly explaining the FlatFire reverse flow motor that made 550+HP.
    Bascially, in this motor it was exhausting through the intake runners and making the exhaust runners the intake system......................much more complicated, but that is the 1 cent tour.
    Enjoy;
    http://www.flatfire.com/flatfire2.htm
  3. A Chopped Coupe
    A Chopped Coupe
    For you SBC guys, here is a Reverse Flow SBC setup that uses flathead V8 distributor and motorcycle carbs.
  4. 4tl8ford
    4tl8ford
    from Erie, Pa
    1. With the exhaust switched it allows the engine to run cooler.
    2. It requires supercharging due to more complicated intake runners.
    3. Makes everone to stop and take a second look.
    4. The Caddy Flathead had intake and exhaust both on top.
  5. CJ Steak
    CJ Steak
    from Texas
    Wow, I kinda forgot about that conversion. That would look great in a rear engine race car from back in the day. That's one helluva build too...
  6. zilly
    zilly
    wow A Chopped Coupe thats dam cool. So how is the conversion done Im assuming the flip the crank so its the wrong way round?
    Do they run cool to the point when a water system isnt needed???
  7. panic
    panic
    WHAT????
  8. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    It should be all in the cam , on the old 4 bangers the 2 intake ports become exhaust, the 4 exhaust ports become intake and the engine can really breath!
  9. Lotek_Racing
    Lotek_Racing
    They even MAKE fuel! You'll need a bigger tank to hold it all. Then Exxon will come to your house, buy your car for 100 bajillion dollars and we'll never see it again!
    Shawn
  10. fullhouse296
    fullhouse296
    from Australia
    See flathead express .steve Mc Guinness ,Perth , Australia
