Technical reverse-twist drill bits......
Discussion in 'The Hokey Ass Message Board' started by 6sally6, Aug 22, 2022.
  1. 6sally6
    6sally6
    When using reverse twist drill bit (when trying to remove a broken stud/bolt) do I also run the drill in reverse or......run it forward?
    6sally6
  2. Run the drill in reverse.
    Stogy, 1oldtimer, porknbeaner and 3 others like this.
  3. Mr48chev
    Won't work as intended if you run it clockwise= forward.
    VANDENPLAS likes this.
  4. SEAAIRE354
    SEAAIRE354
    There’s kind of a feel that goes along with it also. The drill is spinning the opposite direction and you need to put some down pressure on it and when the bit catches and the bolt starts to turn out you need to allow it to come out. If using a hand drill it’s not bad but in a drill press or mill things can get fetched up and you’ll be trying to remove the broken bolt with a broken bit in it.
  5. goldmountain
    goldmountain
    Works better with a Jacob's Chuck.
    Deuces, -Brent- and jimmy six like this.
  6. jaracer
    jaracer
    TIG weld a nut on the end of the broken stud and use a wrench to back it out. Have plenty of nuts on hand as you may have to do this 3 or 4 times. It has always worked for me.
    dirt t and THE FRENCHTOWN FLYER like this.
  7. Turbo26T
    Turbo26T
    Let me add my $0.02 worth...Before you weld a nut to the broken bolt..... Weld a flat washer to the bolt...weld the nut to the washer...Bobs Yer Uncle
    Keeps from welding the broken bolt to whatever its in..
    49ratfink, alanp561, dirt t and 8 others like this.
  8. rusty valley
    rusty valley
    I also like to grind off the cad plating before welding. You'll get a stronger weld
    Cosmo49 and jimmy six like this.
  9. cfmvw
    cfmvw
    I often use left hand drill bits in a Bridgeport for extracting broken screws at work. On the occasion that I can't, I make a drill guide to keep it centered over the broken fastener. A good soaking with penetrating oil helps a lot, too.
    Algoma56 and chryslerfan55 like this.
  10. Dean Lowe
    Dean Lowe
    FYI: They are called Left Hand drills.
  11. Is that right? Lol
    blowby and lowrd like this.
  12. Davesblue50
    Davesblue50
    Yes they are. I used to sell them at O'Reillys
  13. RmK57
    RmK57
    Only thing that I've found that works consistently for a broken bolt is heat. Drill a hole and use a regular easy out on a glowing red broken stud.
    Dan Timberlake and chryslerfan55 like this.
  14. "Easy outs" have never been my favorite method for removing broken bolts..... There's some basic instinct that tells me that screwing or pounding a tapered object into a straight hole with the intent to un-screw a fastener is self defeating.... the wedging action just makes the fit between the tapped hole and the fastener tighter. Drilling with progressively larger drill bits works best for me, although Left Hand Twist Drills make the most sense. JMHO
    warbird1 and saltracer219 like this.
  15. chopolds
    chopolds
    from howell, nj
    I find the left-handed bits work better than EZ outs. Never had much luck with them.
  16. Bearing Burner
    Bearing Burner
    from W. MA
    EZout is a big misnomer
  17. David Gersic
    David Gersic
    from DeKalb, IL
    EZ outs are a great way to turn a small problem in to a bigger one. Drilling out a broken EZ out ****s even harder than drilling out the broken bolt you started with.
    56don, Deuces, Dan Timberlake and 5 others like this.
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    THIS
    I have even removed studs that had broken off below the surface. This saved me removing the head from my motorhome engine, using a MIG welder.
  19. ekimneirbo
    ekimneirbo
    Sometimes you just have to find a shop that has a disintegrator...........
    Deuces and '28phonebooth like this.
  20. exactly ^^^^^^
    The idea is that the drill will hang before it breaks out and spin the broken bolt or stud out.
  21. Harv
    Harv
    from Sydney
    A snapped EZout is the hardest known substance to man. Makes diamond and carbide look like ****er.
    They are good for pulling out main discharge jets (not main metering jets!) from Strombergs though.
    Cheers,
    Harv
    '28phonebooth likes this.
  22. bobss396
    bobss396
    Left hand drills are usually screw machine drills. Shorter is better than longer, unless you need the reach.
  23. Budget36
    Budget36
    Has anyone been successful using a left twist drill bit to get a broken bolt out?
    I’ve never used one before.
    But….begs the question if you’re going to tap a hole and use a left hand thread, I can see using a left twist bit;).
    Cmon. Someone was gonna say it.
    Algoma56 likes this.
  24. they should NOT be called easy outs.
    they should be called HAHA Your ****ed !:eek:
    49ratfink, alanp561, WalkerMD and 5 others like this.
  25. warbird1
    warbird1
    Yes, I have. Mostly on smaller diameter aircraft fasteners; though I've managed to do it on automotive parts also. Pretty slick... when it works.
  26. 6sally6
    6sally6
    X-2!
  27. At work, we call them **** you Overs!
    Deuces and VANDENPLAS like this.
  28. If you buy your “EZ Outs” from HarborFreight, and break one off, they are easy to drill out because they are made of wood!
    49ratfink, alanp561 and VANDENPLAS like this.
  29. deucemac
    deucemac
    Just a small thought here. Years ago I was working in a Lincoln-Mercury dealership and the guy next to me snapped a bolt off in a Capri V8 fuel pump mount. He was panicky about how to get the broken bolt out. I offered to let him use my reversable air drill and my left handed drills. I told him that most of the time the broken bolt would unscrew itself once the drill broke through the end and caught the tip. Off he went and the next thing I hear is him screaming loudly. I run over and here he is with his hand pin he'd between the frame rail and the air drill. He was in tight quarters and when the drill broke through, it spun the bolt shaft out as fast as the drill was turning and squashed his hand. Word to the wise, only put enough speed and pressure to get the screw out. Don't lean on the drill full force and hold the trigger wide open. It could be painful!
    alanp561 and Algoma56 like this.
  30. Mo rust
    Mo rust
    On a side note, I read somewhere that Henry Ford used left hand drill bits in the factory to keep workers from stealing bits.
