Technical reverse-twist drill bits......
Discussion in 'The Hokey Ass Message Board' started by 6sally6, Aug 22, 2022.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    Yes. Once. I was amazed when the screw backed out on the bit.
    Budget36 likes this.
  2. Ricco39ford
    Ricco39ford
    I agree 100% with welding flat washer first then welding nut to washer fill inside of nut with weld then let cool before putting wrench on it, maybe a little penetrating oil. I’ve had good luck with this
    VANDENPLAS likes this.
  3. clem
    clem
    I have mentioned this before.
    Being a farmer and living out of town, I often had to improvise.
    Never used an easy out, - I always drilled a small hole, got a slightly larger allen key, - tapped it in with a hammer and turned it backwards.
    Never failed me, - but your results may differ…….
    Budget36, Algoma56, alanp561 and 2 others like this.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, a couple of times with small diameter screws. An added feature is that the drilling is going to heat things up as well, aiding in its removal. I remember reading a Gus Wilson story where he managed to remove a broken head bolt that way, but then, Gus Wilson could do anything!
    Budget36 and '28phonebooth like this.
  5. finn
    finn
    I prefer the “weld on a nut, with washer” method.
    I couldn’t drill a straight hole in a bolt so I could use an EZout if my life depended on it.
    VANDENPLAS and TrailerTrashToo like this.
  6. 51504bat
    51504bat
    His "Model Garage" was the gold standard for repair shops.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I always wanted to see him have his fill of Silas Barnstable's ******** and physically throw his *** out.
    51504bat likes this.
  8. Poppinjohnnies
    Poppinjohnnies
    I mess with a lot of dead antique 2 cylinder John Deere tractors. The manifold bolts ALWAYS break off in the heads on these things, so I bought a bunch of left hand bits many years ago to help remove the bolts. My advice: Use plenty of penetrating oil and patience. Getting in a hurry will just cause you to screw up a cylinder head and probably something else when you start throwing wrenches. Take your time and start with a small bit centered as perfectly as you can in the broken bolt. When you've drilled through the offending fastener, step up to the next size bit, then the next. Eventually the remains of the bolt will spin out with the left hand bit. The bolt might be paper thin by the time it comes out. Sometimes I've spent 2 or 3 evenings removing just a couple of bolts, but I urge you to take your time and not get in a hurry. Been there, done that, thrown the wrenches.
  9. 57JoeFoMoPar
    57JoeFoMoPar
    I generally despise let hand drills and "EZ outs" because when the bolt breaks off below the surface it's screwed into, inevitably it is not an even surface that you can pilot a drill bit in the center of the bolt, whether in a clockwise or counterclockwise rotation. Obviously not wanting to drill into the side of the hole to destroy the threads, you drill a smaller hole with the drill bit, which requires the use of a smaller extractor. But with meat left on the broken bolt, it generally doesn't want to budge, and the smaller extractor is probably undersized for the bolt you're trying to remove, which then increases the likelihood that you're going to snap it off in the broken bolt.
    I've also questioned the concept of the EZ out since even if everything goes right, what is really occurring is that the wedge shape of the extractor digs into the broken bolt and further increases the force outward on the broken bolt. I can only imagine that this is trying to expand the broken bolt, which is only tightening it in the hole as it further binds the threads of the bolt into the threads of the hole where it busted. That's counterintuitive.
    I have used EZ outs successfully before, but I have snapped them off easily as many times or more. The "nut welded to the broken bolt" trick has been more effective, but when push comes to shove, the things that seem to increase the overall chances of success are dissimilar metals between the broken bolt and the hole it's in, and the application of heat. The welding trick does that just by way of process.
    I'd also add that the late Flatdog here on the HAMB, showed me a great trick to burn bolts out of cast iron with a cutting torch. It works, and is the best method I have come across yet to get a truly busted bolt out that isn't going to budge otherwise.
    alanp561 likes this.
  10. MeanGene427
    MeanGene427
    from Napa
    One thing my gramps taught me many years ago was to not heat around the fastener, but to heat it dead center. It expands the fastener, and fractures the rust in the threads. Do it a couple times, letting it cool off in between, let it cool again, and it will usually come out pretty easily
  11. Dan Timberlake
    Dan Timberlake
    If the corrosion seized full size bolt broke during removal, the high strength but much smaller EZ out or LH drill doesn't stand much of a chance. Until/unless the rust bond is squished or busted.
    Bolts can also break immediately because the installation torque was too much, or fatigued over time because they were installed too loose and were subjected to bending or variable tension loads.
    Those stub bolts' threads aren't usually sized to the tapped hole, so can unscrew fairly EZ. Then LH drills and EZ outs have a fighting chance.
    If the bolt and tapped hole gall ( stainless on stainless can be poison) material starts to "pick up" real quick and form metal nuggets as the bolt is loosened.
    https://www.boltdepot.com/Images/Fastener-information/Galling/Galled-bolt-with-removed-nut.jpg
    Then it is time to machine off the tapped housing, split the nut, or etc.
  12. alanp561
    alanp561
    Nifty idea, I'll have to try that.
    clem likes this.
  13. Driver50x
    Driver50x
    I have a straight (basically splined) set of easy outs from Snap On that I have used successfully many times. The tapered easy outs are garbage.
    warbird1 and alanp561 like this.
  14. I've had some luck using a Dremel Tool to make a centered dimple for a drill bit.
    Especially good if the fractured stub is slanted.
  15. BJR
    BJR
    Since I am left handed I use left hand drill bits all the time. :D
  16. clem
    clem
    Thanks, - a friend of mine rang last year wanting to borrow my easy outs. He was ***uming that I had some, and was surprised at my allen key trick. He said he would try it and rang back 20 minutes later, - couldn’t believe that it worked.
    My mechanical engineer son watched one day and told me that I was wasting my time.
    He too was amazed at how it worked…….
    (Possibly some of the secret is in the strength of the Allen key and that you have ‘leverage’ that an ezy out doesn’t have ).
  17. -Brent-
    -Brent-
    In the last 20 years, that's pretty much all I have used. There has been the occasional nut welded to remove something but it's usually my second option.
    The posts about shorter bits and the chuck are spot in, too.
    Everyone should have a small set in their toolbox.
  18. warbird1
    warbird1
    Another thing I've learned over the years (the hard way) is to center punch the broken fastener as close to CENTER as possible, using a magnifying gl*** if needed. Then use a center-drill to start the pilot hole. They won't flex and move around as much as a standard drill bit will and help to start the hole centered in the fastener.
