Reversing a Vega Box
Discussion in 'The Hokey Ass Message Board' started by Blue One, Feb 10, 2011.
  1. Blue One
    Blue One
    from Alberta
    I searched high and low here, maybe I'm just not good at searching :confused: What I'm looking for is instructions on how to reverse a Vega box for side steer duty on my 26 RPU.
    I have seen a thread on here with pictures and all just can't find it anymore.
    Can anyone help ?
  2. Dreddybear
    Dreddybear
  3. Check out the current edition of Hot Rod DeLux.
  4. Jmountainjr
    Jmountainjr
    The reversing process is the same as any other recirculating ball box: dis***emble, turn the worm gear 180 degrees on the input shaft, plug original input shaft hole with a cup plug, machine the input shaft pre-load adjuster nut for the input shaft and seal. The last part can be done in a drill press, but best done in a lathe so you can get it centered and cut a nice step to bottom out the input shaft seal. The original input seal will be too big on the OD to work. You'll need to pick out a seal with a smaller OD. There is a large slection of .625 ID seals with either .875 or 1.00 OD that you could use.
  5. Jmountainjr
    Jmountainjr
    I'd also look at reversing a 525 box. Same mounting footprint as the Vega, just a bit bigger, super strong.
  6. Rock Island Rocket
    Rock Island Rocket
    Definetely check out the latest issue of Hot Rod Deluxe like Bib said, very good article!
  7. Blue One
    Blue One
    from Alberta
    I'll look at HRD.
    I found this one pic of a reversed Vega box, no instructions on doing it. Sounds easy enough though.
  8. Smilin Jack
    Smilin Jack
    I reversed a Vega box for my 37 Fiat. It reverses just like a Corvair box. Drill out the adjuster nut, plug the other end with a freeze plug and turn everything around.
