Reviving 1965 F100 Ranger field truck
Discussion in 'Off Topic Hot Rods & Customs' started by GlassThamesDoug, May 12, 2025.
  1. GlassThamesDoug
    GlassThamesDoug
    This thing was operated on duct tape and hose clamps.
    1Nimrod, chryslerfan55 and porkshop like this.
  2. GlassThamesDoug
    GlassThamesDoug
    3/8in movement his morning. 3x more washers, 40ft lbs & KROIL.
  3. GlassThamesDoug
    GlassThamesDoug
    Distributor I'm waiting to install.
  4. GlassThamesDoug
    GlassThamesDoug
    Finally......Pulled lower portion of stuck distributor.
  5. GlassThamesDoug
    GlassThamesDoug
    Distributor installed.
    1Nimrod, porkshop, SS327 and 2 others like this.
  6. GlassThamesDoug
    GlassThamesDoug
    There's hope for this thing.....
  7. GlassThamesDoug
    GlassThamesDoug
    Stopped raining, got the****** running.....
    Runs good for 25+ years sitting.
    Have video .mpg running, but it will not upload.
  8. gene-koning
    gene-koning
    You did put a little anti-seize on that dist shaft before you installed it, right?
  9. GlassThamesDoug
    GlassThamesDoug
    Video
    Actually I put white lithium grease on surfaces.
    1Nimrod and loudbang like this.
  10. GlassThamesDoug
    GlassThamesDoug
    Running on the 65 truck fuel tank. Funny, varnish, diesel, sea foam, ...gas...few days soak, drain some off.
    Test its vapor with match in fire pit, lit faster than pump gas I've bought lately. Vapor test, says, yeah it will run. Runs better than straight 10% ethanol gas.....
    1Nimrod, SS327 and loudbang like this.
  11. GlassThamesDoug
    GlassThamesDoug
    Auto trans, all gears working. Neutral safety works as well.
    loudbang and 1Nimrod like this.
  12. 1Nimrod
    1Nimrod
    She's cleaning up nicely, happy happy for you getting her running. Nice ol'Ford Farm Truck.
    Dustin
    (1Nimrod)
    GlassThamesDoug likes this.
  13. GlassThamesDoug
    GlassThamesDoug
    Fuel guage goes to E with key on, will T/S that, might just need sender cleaned from sitting.
    4 ways work...
    Coolant Temp guage works....
    Heater fan...works. blew out another mouse nest.
    porkshop likes this.
  14. GlassThamesDoug
    GlassThamesDoug
    Drove in yard. Quiet no noises in trans.
    Next: Brakes, Springs, Shocks .... tires, probably road worthy.
    People interested... I tell them more I fix = price goes up.
    Picked up the county, state paper work on process to get****le for abandoned vehicle.
    porkshop and loudbang like this.
  15. GlassThamesDoug
    GlassThamesDoug
