Projects Reviving old glass rubber seals ?
Discussion in 'The Hokey Ass Message Board' started by Rustytoolss, May 2, 2024.
  1. Rustytoolss
    Rustytoolss
    Anyone got any ideas of what to use on old gl*** rubber gasket seals to look better. Mine are old and dry looking. ( the actual rubber gl*** gasket/ seals.. like windshield seals etc )
  2. manyolcars
    manyolcars
  3. Rusty J
    Rusty J
    Brake fluid or silicone lube both act like moisturizer for rubber. It will take several applications (wipe it on with a rag) let it sit (not on the paint if using brake fluid) and keep working in more. Kind of like moisturizing old leather seats, eventually the rubber will look pretty decent. I do this on my vehicles yearly.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    Only thing that works on dry and cracked rubber tire paint. Not the silicone dressing but the actual black paint. Anything else and you just end up with shiny cracks
  5. 1971BB427
    1971BB427
    from Oregon
    When I worked at the Cadillac dealer back in the 60's, GM sold weatherstrip conditioner that was simply silicone grease we rubbed into the rubber to bring it back. I still have about 3 big tubes of it that they were tossing out simply because it began to separate. I use it on all of my old cars, even on new weatherstrip to keep it new.
  6. noboD
    noboD
    Glyserin, drug store item, will work. Or find Lestoil in an old grocery store. It's a cleaning liquid hat will make the rubber soft like new. And it will clean tires like you've never seen before.
  7. ClayMart
    ClayMart
    This^^^! ;)
    In later years at least, GM Service Manuals and Owner Manuals specified using dielectric grease (GM branded, of course . . .:rolleyes:) to soften and restore trunk, tailgate, liftgate and door weatherstripping. It also works well to stop squeaking and creaking noises from loose or poorly fitted plastic panels. And it helps make "snap-in" plastic panels easier to ***emble and dis***emble. It doesn't have any solvents that will deteriorate or dry out rubber or plastics.
    :D
  8. AccurateMike
    AccurateMike
    I've heard of wintergreen oil.
    I have not tried for myself. Great rabbit hole though.
    Mike
    Rawrench likes this.
  9. Pete1
    Pete1
    from Wa.
    Bleach works good for softening rubber. The longer it soaks, the better.
    We used to use it on our race car qualifying tires till it was outlawed.
    BE CAREFUL using it around painted and bare metal surfaces. It is slightly corrosive.
  10. stuart in mn
    stuart in mn
  11. Fortunateson
    Fortunateson
    That Gummi Pflege is the stuff Bavarian Motor Werkes recommends...I “think they been recommending itsince before 1965”...LOL
