1952-59 Ford Rewiring 1956 Victoria
Discussion in 'Off Topic Hot Rods & Customs' started by ffr1222k, Aug 6, 2022.
  1. ffr1222k
    ffr1222k
    I have started the process of rewiring my 56 Victoria. I was never aware the factory ran the wiring to the rear for the tail lights and turn signals and brake lights overhead. I am not taking out the original headliner. Has anyone rewired their car and how did you route the wiring to the rear? Can you use these wires, connect the new wires and pull them overhead to the rear?
  2. guthriesmith
    guthriesmith
    Wow. I am no help, but just learned something. I would have never guessed they ran those wires overhead.
  3. ffr1222k
    ffr1222k
    Maybe it is hardtops only. They enter the cowl about the middle of the windshield.
    guthriesmith likes this.
  4. evintho
    evintho
    Since you're running all new wires, can't you run them down low, through the rocker panel and up over the rear wheelwell into the trunk area? That's how I ran my '54 wiring.
    Then just remove your old wires from under the headliner.
    JeffB2 likes this.
  5. ffr1222k
    ffr1222k
    That does look like a good alternative. I would have to take the car a good bit further apart to do that. Yours does look good. My car was a nice complete car until I decided to change to a 5 speed and replace the dash that someone had cut up for a modern radio.
  6. evintho
    evintho
    Removing the sill plate, rear seat and drivers side rear door panel will give you complete access all the way to the trunk.
  7. Paul2748
    Paul2748
    on my 54, I ran all the rear wires under the carpet next to the front seat. Did have to make a small hole in the back seat riser to bring them into the rear.
    JeffB2 likes this.
  8. ffr1222k
    ffr1222k
    I think i will run under the carpet also. I just was surprised how Ford ran it.
    I do like what evintho did.
  9. nosford
    nosford
    I have used a flat 4 conductor cable made for wiring trailers in the past. Very easy to lay flat on the floor then cover with aluminum tape like used for sealing furnace ducting. 4 wires gives you tail light, turn signals, and backup lights if you have them. You can get 20 foot rolls very reasonable at almost any auto parts store.
    JeffB2 likes this.
  10. jailbar joe
    jailbar joe
    an old speedo inner cable is great for feeding wire into blind panels or pillars
  11. bobss396
    bobss396
    On my '59 the wires ran along the transmission tunnel. I did the same thing with the new harness.
  12. jimmy six
    jimmy six
    There were only 5 wires to the rear of the car. If all the original folding clips are there it makes it easier. They were in a protected loom.
    If your ever planning on a rear shelf speaker this would be the time to add the wires, 2 for each one if your a sound guy. The center dome light went the left A pillar.
    A laminated color wiring diagram from Cl***iccarwiring.com is really good for all this.
  13. ffr1222k
    ffr1222k
    Thanks Jimmy six. I still have the Town &Country radio from my 56 I had in 1966. My friend that had a radio shop fixed it for me last year. I am going I am going to use it in the front but I am going to use a bluetooth adapter and amp and put those in the package tray.
    jimmy six likes this.
  14. jimmy six
    jimmy six
    The old loom gets a little gooey when old. There is some new plastic (not the split stuff but wrap around) but I taped mine with Scotch 33 black and laid mine in the stock spot.
    I had a friend convert my stock radio to AM-FM-Bluetooth and use it mostly for my I-phone and listening to Sirius oldies radio. My hearing is ****ty with tinnitus so a front speaker is all I need but the radio has the capability to do just about anything. The wiring is taped up on top of it.
    ffr1222k likes this.
  15. danman55
    danman55
    On my 55 Ford ( HotRodReverend.com/blog ) I wished I had followed this advice since there are some electrical items I want to add. However, this will mean dis***embling the interior and running wires after the fact. Of course, this can be done but I do not relish tearing into things again. :mad: It would have been much easier to run a few extra wires just to have the circuits available to wire to relays and switches in the future.
  16. nosford
    nosford
    I wired a 57 Ford I had many years ago and ran extra wires to the rear for speakers and also for an amplifier if I ever wanted to add one. Drove the car for a couple years and never added a stereo, just used the stock AM radio. Someone I worked with wanted the car really bad and I had my eye on a Falcon Sprint I wanted so sold the 57 and bought the Falcon. About a month later went over to the co-workers house to see all the extra wires laying on the ground with the explanation "it had all these extra wires that didn't go anywhere, weren't even connected to anything" so my good idea was his bad idea. Once I explained what the wires were for he had an Oh **** expression! Oh well, wasn't my car anymore, right? Yeah, till I bought it back a year later!
  17. jimmy six
    jimmy six
    I started making Masking tape flag labels when I added something extra. I was told to by my dad.
    As I add things to my 56 now I attach the wiring, color and size to the laminated schematic I bought.
    down-the-road and ffr1222k like this.
