Technical RHD 63 impala steering shaft issue
Discussion in 'The Hokey Ass Message Board' started by Harleyv89, Mar 25, 2023.
  1. Harleyv89
    Harleyv89
    Hi,
    Brought this car 3 years ago and ive only just got it on the road 4 months ago trying to fix the previous owners stuff ups. I have noticed a hose clamp placed on the upper steering column above the spring stop clamp? Obviously not from factory. If its above the spring stop clamp where is the spring? Inside the mast jacket? Or is it gone which is why the spring is there?
    Note:
    • Steering wheel can be pushed forwards about 10mm and it returns back
    • Isn't the spring stop clamp meant to be hard up against the mast jacket?
    • The upper coupling has a little bit of movement in it
    • I can see what looks like the bearing above the modern hose clamp
    I have attached a image.
    Thanks for any help you can give.
  2. BJR
    BJR
    You need to pull the column and take it apart and see what's going on.
    Budget36 likes this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pic. always select full image when posting pics. especially when looking for help... hard to say what is going on with that hose clamp. maybe the lower bushing is shot? as BJR said, you should pull it apart and fix it
  4. saltflats
    saltflats
    from Missouri
    Supposed to be a spring there where the hose clamp is.
    Budget36 and Moriarity like this.
  5. 61Cruiser
    61Cruiser
    Agree with @saltflats, should be a spring where the hose clamps sits. Maybe the coupling further down the shaft has been worked on before and the previous owner “deleted” the spring? Could be a good time to pull it apart as well when you correct the spring issue.
    Cheers
    61Cruiser
  6. Harleyv89
    Harleyv89
  7. Harleyv89
    Harleyv89
    On mine it is a full image and can clearly see the clamp without zooming in and thats on a iphone
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    What you originally posted was a thumbnail pic. Even when clicked on they are half the size of the full images. It is helpful when you are posting pics looking for help to make them as large as possible, the only reason you’d is a full image now is because I edited your post and changed it to full image
  9. Harleyv89
    Harleyv89
    Mate I haven't changed the image at all its exactly how i posted it. And who cares anyway no one else had to zoom in so chill
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    come on man, I am trying to help you, you posted a thumbnail and I changed it to a full image...
  11. Harleyv89
    Harleyv89
    If that helps you sleep at night mate I wouldnt care enough to even bother doing that haha
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I changed it back. just pretend I was never here
  13. 52HardTop
    52HardTop
    The "mate" from down under, aint much of a mate!
  14. Harleyv89
    Harleyv89
    Ohhhhhh i was reading it wrong haha you changed it i thought you said i changed it my bad it was nearly midnight here reading it half asleep
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    that's cool man, I changed it to full image again. It is easier for us old geezers eyes
  16. DDDenny
    And cool heads prevail again!
    Moriarity likes this.
  17. Harleyv89
    Harleyv89
    Cheers mate
