Ricer motor? Hack . . . cough . . . choke...
Discussion in 'The Hokey Ass Message Board' started by C9, Jul 25, 2005.
  1. Skeezix
    Skeezix
    from NorCal
    We did evos on the f3 Lolas at Jim Russell racing unlike my former employer I suggest you:
    remove the turbo, run pectel ecu, a pilot bearing and a single plate clutch. Biggest challenge is mating the gearbox, choose wisely, for road worthiness. They are somewhat heavy blocks for racing. Avoid Haltec ECUs they are poorly constructed.
  2. Ob1
    Ob1
    I have some go-fast goodies if anyone chooses a 2.2 SOHC Mopar.
  3. Natedrag
    Natedrag
    2.2, 2.5 Mopar all the way. Easy to rwd, they came in Dakota pickups w/ a 5 speed. They came carbed or TPI, or turbo EFI. I'm helping a friend build his 87 Shelby Charger w/ a 2.2 T3, twin cam, big boost etc. 85% done, hope to run next month.
    2.3 from a Ford Ranger is another option or 2.3 Turbo Coupe Thunderbird.
    BTW, just do EFI, take all the pieces from doner car.
  4. Cymro
    Cymro
    I don't know if this is the same enrine as the Izuzu mentioned earlier, but in the uk the Vauxhall/Opel "Red Top" 2.0 litre twin cam 16v is very popular kits are available for mating to a ford T5 box
    This engine can produce close to 200 bhp without major spending (2x45DCOE WEBBERS)
    Another alternative is the Ford Duratec / Zetec engine I imagine this is available in America.
    Check out this site
    http://www.burtonpower.com/Default.asp
  5. Cymro
    Cymro
    Oops I should have added that these engines are the most popular for Lotus Seven style cars in the UK converted to RWD using the Sierra 5 speed box.
  6. cheveey57
    cheveey57
  7. denis4x4
    denis4x4
    from Colorado
    I'm building a Model A Huckster and was looking for something different for power. Pulled a 1.8 SOHC with a 4 speed from a 1975 Ford Courier. Bought an Offy intake set up for a Weber downdraft. Petronix ignition, reground cam, lightened flywheel, balanced and a larger oil pan.
    Compared the Courier with a '31 Tudor and the specs are almost the same. Big difference is HP, Model A is 40 HP and the 1.8 SOHC is 119 HP before modifications.
  8. Nissan's KA24 3 valve engine was built by the millions in FWD and RWD (240sx and trucks). Can easily be converted to carbs and computer-free ignition.
  9. zman
    zman
    from Garner, NC
    me too, he is missed...
    now the newbs that don't read through the thread and reply anyway tickle me a little....
    RIP C9....
  10. brandon
    brandon
  11. gmans356
    gmans356
    from MDR
    I was kicking around putting a late 60s or early 70s Datsun 510 engine in one of my bellytanks..durable and run great and fast and can be bumped up to make great Horse power. Weber carbs. I saw a Model A with one in it and they even installed air and a 5spd with juice brakes, otherwise it looked stock and was way too fast! should have bought it for the 4500 bucks
  12. haroldd1963
    haroldd1963
    from Peru, IL
    I would go with the Ford 2.0L Duratec/Zetec engine. They have been used for years in the Focus, ****** ZX2, Fusion, and Mercury Milan. Plenty of go fast parts available. There is even a Midget Open Wheel series running these engines.
  13. model.A.keith
    model.A.keith
    X2.............still .....it's good to see some of his words again.
    RIP C9
  14. Dchaz
    Dchaz
    ok I'll get reamed for this but Honda Vtec from the S2000. Stock 240 HP, with a close ratio 6 Speed. A friend of mine uses them in Lotus super 7 replicas he builds. 0-60 in 3.5 sec
  15. brandon
    brandon
    i heard of a guy using one in a bonneville car that went 200+.....guy said it still had the stock wiring harness all....
  16. havi
    havi
    R.I.P. C9, and Johnnyfast, who also posted here. Old thread, I know, but...
    Cosworth:
  17. exactly.........:(
  18. Da Tinman
    Da Tinman
    yeah.
  19. ZRODZ
    ZRODZ
    Yeah, I'm surprised no one has brought this little gem up before. The 2.4 has vvt and that makes the computer issue raise it's head in a major way, but the 2.2 ecotec is a little easier. Most are fwd but they are dead simple to turn fore and aft and will bolt up to the Solstice 5 speed. Getting hp is just a matter of $$, the more you pay the more you get (like that's different?).
