ride height 33-34 Grill
Discussion in 'The Hokey Ass Message Board' started by Aviator, Dec 13, 2012.
  1. Aviator
    Aviator
    Looking a 33-34 build pictures it seems that many grills are very low with little ground clearance. How much ground clearance is standard? What would be considered the minimum clearance?
  2. chaddilac
    chaddilac
    High enough to clear a Opossum!! :D
  3. freeze plug
    freeze plug
    from Canton, CT
    i too was wondering the same thing as I will be going through this soon
  4. Rocky
    Rocky
    Classified Editor
    I'm shootin for 4-5 inches. Thinking of building a heavy "chin", painted black to go under the tip of the grille to protect it from road hazards...still in the "thinking" stage for mine.
  5. da34guy
    da34guy
    If ya can push a pool ball down the road, thats just about right
  6. brigrat
    brigrat
    from Wa.St.
    Considering the cost of a '33 '34 grill I would be on the conservative side..........................
  7. HOTRODPRIMER
    HOTRODPRIMER
    If the bottem of the shell is folded under it's too low!:D
    Seriously,,3 to 4 inches you should be safe if you use caution entering and exiting parking lots. HRP
  8. flatheadpete
    flatheadpete
    from Burton, MI
    Bout this much.....
  9. Luke4554
    Luke4554
    Good god thats sick, but that would scare the **** out of me.. Id have to get my drivers seat re-upholstered every year cause i would just drive around with my *** cheeks clinched everywhere
  10. brigrat
    brigrat
    from Wa.St.
    If he was running fenders it would be even lower! Is OP running fenders?
    Nice build by the way flatheadpete, one of my favorites if it means anything!
  11. Jalopy Joker
    Jalopy Joker
    ..... a bit of common sense should be used, even if grill is not perfect. at least install some type of protection for lower end of grill. at some time will go over something too high, or too close, and you likely say something more than Oops!
  12. flatheadpete
    flatheadpete
    from Burton, MI
    Far from sick....actually quite healthy with a Hemi and a 5 speed.......what is it with 'sick'?
  13. Luke4554
    Luke4554
    Wtf? .. alright forget it
  14. da34guy
    da34guy
    Luv it, That 1 could push a marble !!!!!!!!!!!!!!!!!!!
  15. who.s 34 loved to see more cool ride
  16. 28TUDOR
    28TUDOR
    A buddy of mine had his 34 redone and we'll use that term loosely. The front fender connector, point, are whatever it's called was 2 1/2" off the ground. He couldn't pull in his driveway without it dragging. Anyway, I was able to raise it to 4 1/2", at least he can drive it now.
    28
  17. Kirk Hanning
    Kirk Hanning
    The grill shell on the red 34' is exactly 3 1/4" off of the ground. I just measured it. In fact I laid the shell back 6 degrees with the top being the fulcrum to give me more clearance otherwise it would be resting on the ground. It worked out rather well because the angle of the grill matches the angle of the A pillar that I leaned back when chopping it 3". In my hill billy opinion it gives the side view a more pleasing look with the the 2 vertical angles matching being the grill & A pillar.
  18. fordcpe
    fordcpe
    Bottom of my grille is 6.5" bottom of fenders 5.5" bottom of bumper 6.5" To high but I never hit anything or worry about it. Darrell
  19. geoking
    geoking
    More pictures please!
  20. Darenski81
    Darenski81
    from Flint, mi
    ImageUploadedByTJJ1355446585.691170.jpg grill is 3 1/4" off ground with 5" channel on body and 4" lowered suspension
  21. flatheadpete
    flatheadpete
    from Burton, MI
  22. Jeez, that car is bad***.
  23. flatheadpete
    flatheadpete
    from Burton, MI
  24. tfeverfred
    tfeverfred
    Nice ride, Pete. By the way... "sick" means it's bad ***.;)
    That look is why I think 34's are cooler than 32's.
  25. flatheadpete
    flatheadpete
    from Burton, MI
    Thanks Fred but its not mine. Kirk Hanning built it. Here's another full frontal:
    Btw.....I know what sick is supposed to mean. It just sounds so stupid!
