Right Hand Drive steering questions.
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Mar 9, 2011.
  1. Commodoreswab
    Commodoreswab
    from West TN
    cheap and plentiful where in that config?
  2. DD COOPMAN
    DD COOPMAN
    Halfracks, Land Rover steering boxes, RHD Mitsubishi pick-up power steering boxes, 350 SBCs...it just don't get much more TRADITIONAL. DD
  3. chaddilac
    chaddilac
    I found that a 46-8 chevy car box would work well, cause the pitman arm is on the inside of the frame rail, also check out the early Jeep military style... they had a cool box that had the pitman arm on the inside.
  4. JSBriggs
    JSBriggs
    from Auburn, CA
    Cheap and plentiful here in the US. That is a LHD box with the column for the 3 spoke style steering wheel. The earlier ones('66 and older) for the banjo style wheel can be a bit more expensive and harder to come by, but still relatively available. The only reason to hunt down an earlier box is if you want to run the banjo wheel (see pic).
    -Jeff
  5. Commodoreswab
    Commodoreswab
    from West TN
    Boy thats great news for me, I have been toying with making this car RHD and love the looks of that rover box. Any idea how many turns lock to lock?
  6. JSBriggs
    JSBriggs
    from Auburn, CA
    Just a little over 4 turns and will rotate the arm 80°. FWIW, the stock arm is 5-1/8" long.
    -Jeff
  7. mgtstumpy
    mgtstumpy
    Another option, older built LHD cars in US often used Falcon / Mustang boxes turned on their side for push / pull steering. Plenty of similar RHD early Falcon boxes here in Australia that could be mounted the same way on RH side.
  8. sickboy138
    sickboy138
  9. nobby
    nobby
    any one know the ratio 18-1 or 24 - 1?
    note the mounting foot is flat, unlike the oem vega, has an inch of threads too.
