Technical Riley Intake?
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Mar 3, 2024.
  1. ‘28 RPU
    ‘28 RPU
    I foolishly bought a good looking Riley intake manifold (from this site) for mu B motor ***uming that it was original (I frequently forget that almost everything as been cloned by now). I also was unaware that those manifolds are for a Riley head although it can be modified to fit a stock motor.
    Can anyone tell me how to determine if it’s an original or a copy? Does it have enough value that I should not modify it?
  2. Dan from Oakland
    Dan from Oakland
    Can you post up a picture so we can see what you have?
    deucemac likes this.
  3. ‘28 RPU
    ‘28 RPU
    I have never posted pictures on here before but I will give it a try
  4. ‘28 RPU
    ‘28 RPU
  5. Fordors
    Fordors
    I would say yours is a newer part using the Riley name with a modification to differentiate it from original, AFAIK Riley cast his name in capital letters and did not extend the “tail” of the R to underline the name. Also, I don’t think George Riley ever made a manifold with the three bolt Stromberg pattern, he concentrated on the Winfield/Riley square bolt flange.
    He also made manifolds with two bolt flanges that were more street oriented to use a Ford A/B carb or the 1 1/4” Zenith. Those used the original Ford manifold to block bolt spacing.
    tractorguy and Jeff34 like this.
  6. winduptoy
    winduptoy
    Now all you need is the head
    Okie Pete likes this.
  7. ‘28 RPU
    ‘28 RPU
    You are right Windup
  8. deucemac
    deucemac
    You might want to get a hold of the Hermans at H & H flathead. I talked to Mike at the GNRS because he had some Riley things on display. When George Riley died, he owed a lot of money to John Vesco. Vesco got all of Riley's patterns and castings. Vesco got Fred Lobello to machine new castings made from Riley patterns. I was good friends with Fred Lobello and remember him doing all the machining the way Riley had intended. When both Fred and Vesco died, H &H bought the tooling. I talked at great length with Mike Herman about the history and his purchases. He would know of your part is original or a knockoff.
    Illustrious Hector likes this.
