Rim leaks...
Discussion in 'The Hokey Ass Message Board' started by Chaz, Apr 30, 2009.
  1. Chaz
    Chaz
    We've got a problem with a set of 28 inch OD Goodyear Eagle Frontrunners. The tires loose air at the rim . Both the tires and the rims are brand new and in good shape, but they wont seal. They leak down in about two days. I've had them remounted twice. Some of you tire gurus may know a way to make this seal. Any ideas?. I'm not wanting to tube these or use slime cause they're for a high speed application. Is there some compound/sealant I dont know about?
    FWIW I've got a set of 26 inch on the rear, and they sealed fine.
  2. Aftermarket wires come sealed with a slathering of silicone caulk around the wheel. Your welds or rivets leaking?
  3. Shifty Shifterton
    Shifty Shifterton
    Are you meaning at the bead, ala bead sealer. Or thru the casting? If it's thru the casting paint the inside of the rims.
    good luck
  4. Chaz
    Chaz
    It's leaking at the bead.....
  5. Chuck, I've heard weatherstrip glue will work.......but again I HEARD that---no proof. Plus it's a high speed ap. so.....:eek: I don't wanna be responsible for killing you!
  6. flatheadpete
    flatheadpete
    from Burton, MI
    Any type of 'sealant' used on the rim beads will eventually ball up and cause worse leaks. Even on the front, the tires WILL move on the wheels. HAve them dismounted and thoroughly clean both the bead surfaces on the tires and wheels. Make sure whomever is remounting them uses a proper lubricant whe doing so. And, double check the tire valves.....also a common cause for leaks. A little sealant on the valve won't hurt....just might make a mess on your wheels. Good luck.
  7. Harry Bergeron
    Harry Bergeron
    from SoCal
    I would try rubber cement.
  8. Drive Em
    Drive Em
    I use a cup of un-dilluted dish soap to get slicks to stop leaking, they will still leak down, but it will take a couple of months.
  9. iowaboy
    iowaboy
    from Iowa
    Have you driven on them yet? Sometimes the bead doesn't seat fully when they are inflated, but a short drive will flex the tire enough to seat it. Worth a try.
  10. NVRA #84
    NVRA #84
    We use clear non hardening silicone on the inside beads prior to applying air pressure on our circle track tires.
  11. pan-dragger
    pan-dragger
    any good tire shop will have some bead sealer, it's light tack but i should solve your leak problem.
  12. pan-dragger
    pan-dragger
    if you guys are using nitrogen, that silicone will cause some crazy air pressure problems on the track, we used to use that same method at the track on our late model, until we discovered the silicone spray was giving us the headaches.
  13. oldspert
    oldspert
    from Texas
    In the old days, just after tubeless tires came out, if we had a rim leak like that we would wipe plain old brake fluid on the bead before mounting the tire. It would soften the sealing bead and stop the stream of bubbles.
  14. Toymont
    Toymont
    from Montana
    Last time we took them to have them checked, they said they dismounted them and used a bead sealer on them, Did not seem to work tho. They have not been driven on yet. Just used to roll the belly tank around the shop. Like Chaz said the ones on the back have never been a problem.
  15. jonzcustomshop
    jonzcustomshop
    Since they are the drive wheels, is it possible, or would it work to screw/bolt them on like on a drag car?
  16. We had that problem before and used Gaska-Cinch >>>>.
  17. Goztrider
    Goztrider
    from Tulsa, OK
    I've used bead sealer for smaller and less problematic leaks, and I've also used clear silicone before to seal a bead completely. Both work great, and the silicone will seal up the largest and nastiest of leaks.
  18. Raven53
    Raven53
    from Irwin Pa
    Nope... Nope ... Nope .....sold tires since I was a kid go buy yourself a container of Murphys oil soap paste ...dismount the tire and coat the bead with a hand full of paste ......mt the tire and reair .......leak will stop and no harm done to the tire or rim ......old timers did it for years works every time....good luck
