Technical Rim Offset’s ?
Discussion in 'Traditional Hot Rods' started by mark hogan, Apr 4, 2024.
  1. mark hogan
    mark hogan
    Was wondering on a traditional build running full fenders. Lincoln brake drums and 5” front drop & 2” rear drop. What offsets really work well? Was thinking 16x7 - 2-1/2 O.S rear & 16x4 1-1/2 O.S front using 35 wire set up all around? Any pro’s or con’s would help before purchase would help. Thanks. Hogan IMG_4591.jpeg
  2. ‘28 RPU
    ‘28 RPU
    I’m interested in the exact same question and does anybody know the offset of the ‘35 wheels?
  3. alchemy
    alchemy
    16x8?! Way too wide.
    I think it seems to work best on old Ford derived suspensions to use centered wheels.
  4. mark hogan
    mark hogan
  5. mark hogan
    mark hogan
    Thinking 1-1/2 O.S. Off the top guess.
  6. chickenridgerods
    chickenridgerods
    from DSM, IA
    Are you trying to build a 1970s styled car or something from another era?
    The '35 style wires are not 8" wide. Are you planning on cutting them out of their original rims and welding them into new ones?
    None of the changes you've made warrant 8" wide wheels. They don't really "push the envelope"; they're pretty tame and common, TBH.
    mark hogan likes this.
  7. mark hogan
    mark hogan
  8. miker98038
    miker98038
    That looks damn good the way it is. I’d just finished it and get on the road. Or have Anthony drop by, I’ll bet he’d drive it.
  9. krylon32
    krylon32
    from Nebraska
    I've done a couple sets if early for customer cars both used stock 35 wires on the front with 500/16 Excelsiors and on the rear 18 inch 32 wires widened about 2 inches on the inside with 700/18 Excelsiors. Makes a great combination on a highboy or full fendered early Ford,
    38Chevy454 and mark hogan like this.
  10. mark hogan
    mark hogan
    Thanks, I’ve seen this set up. 18” on rear and 17” up front. Rims were out of Wheelsmith. Thank you for the input. Never thought of the Excelsiors brand tire. Could be an option.
  11. gimpyshotrods
    gimpyshotrods
    Be careful not to interchange offset and backspacing.
    The former is how far, plus or minus, the wheel mounting surface deviates from the center line of the wheel.
    The latter is how far the wheel mounting surface is from the inner lip of the wheel.
    A 16" x 4" wheel with 4-1/2" of offset would look like a front wheel on a dually truck, with the wheel mounting surface 2-1/2" past the OUTER lip of the wheel
    A typical 16" x 4" is centered, as in 0" offset, or 2" backspacing.
    For another example, a 15" x 10" -1.5" offset, or 3-1/2" backspacing.
  12. gimpyshotrods
    gimpyshotrods
    16" x 4", 2" backspacing, 0" offset.
  13. mark hogan
    mark hogan
    Thank you great point. I did goof on my post on front your correct on front at 1-1/2 or zero, rear’s could use 2-1/2 just to keep tire at fender. Seems to be the norm.
    gimpyshotrods likes this.
  14. ALLDONE
    ALLDONE
    thats how I measure back space, wheel company's measure from the top of the lip... not from where the tire mounts... some times that 1/2'' throws the whole wheel off for me...
  15. twenty8
    twenty8
    Backspace should be measured from the inner edge of the wheel lip. If you don't measure it this way you will always get a figure that is at odds with the standardized method used by wheel manufacturers.
    ottersea, mark hogan and 57Fury440 like this.
  16. 57Fury440
    57Fury440
    twenty8 is right. If you measure a 5 & 1/2" rim from the outer edges, it will measure 6".
  17. ottersea
    ottersea
