Rim straightening machine
Discussion in 'The Hokey Ass Message Board' started by zgears, Aug 23, 2010.
  1. zgears
    zgears
  2. That is a very interesting machine!!
  3. Bearing Burner
    Bearing Burner
    from W. MA
    I had a pair of Aluminum Front wheels straightened for $50.Most large towns have some one who straightens rims.
  4. zgears
    zgears
    Has anyone straightened a steel rim manually?
  5. Yes, I want to know the answer to that one. I have an IH rim that I need to straighten. Anyone got any ideas on how to?
  6. dragster dude
    dragster dude
    if youbend it someone will build a machine to fix it
  7. many years ago Bear Alignment use to make a wheel straightening machine. i have been checking ebay , cragislist , farm auctions, etc trying to find one for myself with no luck. fortunately a local shop has one...i have a `40 Ford 16" X 4" there right now for straightening
  8. unkamort
    unkamort
    what he said... check around some hi-end body shops and see who they sub out to. Can't think of the local off hand, but I see they have runners out to pick-up/drop off on the road all the time.
  9. couverkid
    couverkid
    I know a guy that has one straightens wheels for $20 each.
  10. Atwater Mike
    Atwater Mike
    Yeah...I used to straighten 'em at Reinegger's Frame & Wheel on Alma Street in San Jose.
    Old Mr. Reinegger p***ed away, and the new owner didn't know the function of the horizontal spindle was to check runout, and straighten bent wheel rims. (he had an ego syndrome that refused to allow him to believe me that I was able to straighten bent wheels)
    There was a spindle head (flat round heavy steel flange drilled for various lug patterns: largest were for Ford Wide-5.
    There was a mechanical rack pressbar that came down to push the outside back to center.
    (the wheel then could be inverted, to push the 'inside' back out.
    Amusing phenomonem about bent wheels: Seemed that the real bent ones straightened with one push; the slightly bent ones had to get adjusted 3 times!
    I always bent them cold. Hydraulic bottle jack indexed from radius allowed spinning of wheel in between pushes. Also, a set of 'spanner' wrenches, 12"-16", with 30* angle; looked like non-adjustable 'crescent' wrenches, with fixed size slots, 3/32", 1/8", 5/32".
    The shop had been there since the 1880s. The new building went up in '50, but the old shop adjoined it, right behind. It had an ancient blacksmith's forge, used by Mr. Reinegger's Dad, and the best anvil I ever laid a hammer to. Loved that shop. Wish the new owner had had a brain.
  11. Anybody on the East Coast straightening rims. I need to get one straightened very soon or buy new.
  12. wvenfield
    wvenfield
    East Coast? There is a place in Columbus Ohio that does a great job on straightening wheels. I'll get the name if nobody else comes up with it.
    I believe they have a trailer that they travel in also. They did a couple very expensive Mercedes wheels for a friend of mine. Excellent job.
  13. I think that is what our shop has, large overhead arm?
  14. bobss396
    bobss396
    Sure, lots of them too. Sock the rim down on an old Coats 20/20 and have a go at it with a truck tire hammer!
    Bob
  15. willielehigh
    willielehigh
    I have one for sale
  16. willielehigh
    willielehigh
    in new jersey cell number 805-612-2444
  17. Rusty O'Toole
    Rusty O'Toole
    Call around your local tire stores, someone in your area must do this. While you are at it, they can bead blast and paint your rims too.
  18. blue 49
    blue 49
    from Iowa
    I just straightened a wheel with a bent bead to mount up and use as a roller. 18" pipe wrench and a hammer. It looks true and the tire is holding air.
    Blue
  19. Montana1
    Montana1
  20. k9racer
    k9racer
    Speedway has a tool for straighting the lips of wheels. Most circle track guys that run steel wheel have one.
  21. Wayne67vert
    Wayne67vert
    I also used this company to straighten a steel 17x6 rim for my '38 Chevy truck. $50 and did it while I waited.
  22. Montana1
    Montana1
    Just did another one yesterday. Same thing, excellent job!
