Technical Rim/tire size
Discussion in 'The Hokey Ass Message Board' started by dtwbcs, Dec 18, 2018.
  1. dtwbcs
    dtwbcs
    from Brenham,TX
    1958 GMC 1/2 ton truck bone stock suspension 6 lug - currently P215/75R15
    What is the biggest wheel tire combo i can use without issues? Wanting to get new tires & rims.
    Looking at the chrome steelies / wide white wall tires
  2. dtwbcs
    dtwbcs
    from Brenham,TX
    chromesteelie.jpg Something like this...
  3. squirrel
    you might be able to fit 275/60R15 on the back, with 8" or 8.5" wide wheels, with the right back spacing.
    measure first!
    also measure the front to make sure the tires won't hit the tie rod ends.
    but if you're putting whitewalls on it, then pretty much any normal size tire will fit.
    dtwbcs likes this.
  4. dtwbcs
    dtwbcs
    from Brenham,TX
    I think what is there now is a little narrow but not sure-
  5. swade41
    swade41
    from Buffalo,NY
    L78-15 is a decent size rear tire, if you are using bias ply, I don't know what that would correspond to in radial
    dtwbcs likes this.
  6. squirrel
    it's about 235/75, sort of.
  7. blowby
    blowby
    from Nicasio Ca
  8. 32Dan
    32Dan
    from Chino, CA
    I have 215/70-15 on front & 255/70-15 on rear (29” tall) of my ‘56 3100 and no rubbing
    dtwbcs likes this.
  9. dtwbcs
    dtwbcs
    from Brenham,TX
    Ok
  10. squirrel
    be sure to measure....
