Projects Rip and tear ***UPDATED***
Discussion in 'The Hokey Ass Message Board' started by Chris, Sep 29, 2009.
  1. thunderbirdesq
    thunderbirdesq
    Nice work Chris, Looks like fun!
  2. loudpedal
    loudpedal
    from SLC Utah
    F-1 crossmember fan here... done it a few times. Looking good my friend.
  3. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Wow, squeezing a V8 into an early ford seems to have the same issues for most years huh?
    I am not sure about the exhaust problem because I have never dealt with a Flathead (yet) but on my Chevy V8 I know that flip a p***enger side exhaust manifold over to the drivers side you can then dump out the front instead of the back giving you tons of space for the steering box.
    The radiator problem is one that I'm sure you'll figure out once you sit and stare for a bit. Like I said before, it funny how the same swap in two different cars can yield different result and problems that arise.
    Stop ****ing around with those trucks and get this thing finished first!!!
  4. russellmn
    russellmn
    Lookin good Chris! Hey, you get my check???
  5. j ripper
    j ripper
    from napa ca.
    looks good so far chris. what are your plans for the rearend?
  6. Chris
    Chris
    Yes, it's an F-1 cut to fit the A frame just like how the Bishop/Tardel book shows.
  7. Chris
    Chris
    Cool Kris. If I go that route I'm sure I'll have a question or two for you :D
  8. Chris
    Chris
    Can't really run a manifold because the steering box is right up next to the block, between the center and rear exhaust port. So I'll just have to make a set of headers were those ports just dump strait down. We'll see, I'm sure theres a solution out there ;)
  9. Chris
    Chris
    37-40 banjo with a "T" spring located with some snazzy hangers I made up. Wait and see!!!
  10. Chris
    Chris
    Yep, just got it! Going to find a nice box and get your stuff shipped out probably early next week!
  11. tikidiablo
    tikidiablo
    from so cal
    Following this thread closely as I am ready for my next priject. Thanks for the tips and all.
  12. spence-d
    spence-d
  13. Chris
    Chris
    Thanks Spence-D!!! Lots of great info there...just wish the pics would open bigger :D
  14. 41 Dave
    41 Dave
    Chris, Looks like you are making some great progress on your Roadster ! Looks like I need to get the Bishop/Tardel book. Seems to be a good read on "A" builds. May use some of that on my "A" Modified.
    41 Dave
  15. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Hows the frame coming. Did that k go in fairly painlessly?
  16. Chris
    Chris
    Dunno yet, frames at the blasters and I'm out of town helping my Brother move. Oh joy!!!
  17. Chris
    Chris
    Ok, so got the frame back from the blasters and mocked it back up. I got a little longer fan at the junk yard and I think it will work perfect. Hoses clear, too. So, I think I can safely begin to make my engine mounts.
  18. Comet
    Comet
    Chris, what's your fan to rad. clearance? Looks about 1/4" or so, might be the pics. Do you have enough for engine shake or frame and fan flex?
  19. Mark H
    Mark H
    from Scotland
    Great progress Chris.Looking forward to your next up-date.
  20. Chris
    Chris
    Yeah, it's a little more than a 1/4". I think it will be fine, I need it as far forward as possible to clear the radiator hoses.
  21. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I hope 1/4" is enough for all that shake fan flex etc because I am still trying to squeeze that SBC in my '35!!!
    Looks awesome Chris! Get those mounts in and whip the brush out. I want to see that frame in shiny gloss enamal!!
  22. Chris
    Chris
    I think a 1/4 inch is pretty close but should be fine. If it were a little farther back, that would not hurt either. No I gotta figure out the mounts and pedals...once that hump is cleared I should be on the downhill side.
  23. SinisterCustom
    SinisterCustom
    You'll be fine Chris....I had less than that on mine..and we all know SBC's "shake" more than flatty's.:D
  24. Dirty Dug
    Dirty Dug
    Won't you need enough room between the radiator and the fan to install a FAN BELT? Or are you planning to remove the radiator to do it?
  25. couverkid
    couverkid
    Oh Doug that is just a minor detail.Maybe he was just going to unbolt the radiator support rods?
  26. NealinCA
    NealinCA
    Or just unbolt the generator from the intake (you have to loosen it anyway) and slip the belt on from the back. That's the way I do it on my 32.
    Project is looking good Chris. Keep the progress pics coming.
    Neal
  27. lorodz
    lorodz
    comeing along nicley....keep it up ...
  28. Chris
    Chris
    Alright, to settle the debate I went and measured... I have 3/4" fan clearance and yes Doug, I can slip a belt down between the radiator and fan :D
  29. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Nice that should be plenty. I really need to shoot for .75-1".
  30. Chris
    Chris
    That should be no problem with those electric fans your using...
