Hot Rods Rjays swinging pedals
Discussion in 'The Hokey Ass Message Board' started by 51box, Aug 31, 2023.
  1. 51box
    51box
    from MA
    So I have the Rjays swinging pedal set in my car that uses a 60’s Chevy truck master cylinder and slave for the clutch. I went to bleed it today and the brakes feel great but the clutch pedal is an absolute bear to push. It feels twice as hard than my other car with mechanical linkage. I did switch the guts of the master side to side so the right parts are with the clutch/brake sides.
    Any one that has this setup are you experiencing the same thing or should I be looking to try a different slave or master cyl? Maybe one is defective?
    Thanks for any info, Joe
  2. krylon32
    krylon32
    from Nebraska
    The hard pedal is usually caused by a mismatch between the slave bore and the master cylinder bore. I've done a couple cars with R-Jays swing pedals and the pedal ratio is good. What are you using for a clutch slave? If I'm using a black Wilwood pull slave with a 7/8th bore I sleeve the clutch side of the master cylinder to 3/4. If I'm using one of my T5 slaves which is a 1 inch push I sleeve the Master to 7/8th. I've redone several of the truck master cylinders using a machined bronze sleeve with a Wilwood master cylinder rebuilt kit for the guts.
    rod1, vtx1800 and deuceman32 like this.
  3. RICH B
    RICH B
    Or, you could use a Chevy truck slave cylinder.
    Tman likes this.
  4. 51box
    51box
    from MA
    I am using the 60’ Chevy truck slave with a stage 2 McLeod clutch
  5. 51box
    51box
    from MA
    So I have been doing some digging online and found that even though the master has 1.125 bore you can buy a slave cyl with either 1” or 1.0625” bore from rock auto. I checked my part numbers and lo and behold I bought the 1” , I guess without even knowing they made 2 different ones.
    The 1.0625 is on order I’ll update this with the results.
    bob b., Tman, RICH B and 2 others like this.
  6. Dennis D
    Dennis D
    When I put my car together I put a diaphragm Schieffer clutch in it and didn't like the pedal effort at all. I ended up getting a stock chevy diaphragm pressure plate and like it a whole bunch better. I am using the same m/c-slave cyl. set up that you have.
  7. 51box
    51box
    from MA
    Im also using a diaphragm setup, I hope I don’t have to change it out at this point. Do you know if you have the 1” or 1.0625” bore slave cyl by chance?
  8. Dennis D
    Dennis D
    I don't and I just looked at it and there are no stampings on it. It looks like it might be the bigger one judging from the od of it. I may have bought this one from Dorman, but I sure don't remember.
  9. seb fontana
    seb fontana
    from ct
    Check the MC bore sizes, I had one that one bore was 1-1/4, don't remember which side.
  10. pprather
    pprather
    I think typically, the brake and clutch cylinders are different diameters on these GM truck duals.
  11. junkyardgenius
    junkyardgenius
    from Kernow
    I,m running a 60s Chevy pickup master cylinder. My brake and clutch were both really hard to operate. Had the brake side sleeved down to 15/16 and the clutch to 7/8. So much easier to operate now. Wife says the clutch is easier to use than her modern fwd crock.
    pprather likes this.
  12. 51box
    51box
    from MA
    Just an update to this, I changed out the 1” to the 1 1/16” slave and it is a night and day difference. I could barely get the clutch pedal to depress with the 1” slave. The 1 1/6” version feels mores like mechanical linkage, not too soft.
    Chucky, pprather and RICH B like this.
