Projects Road to Redemption: 49 Chevy Coupe Build
Discussion in 'The Hokey Ass Message Board' started by deto, Sep 11, 2014.
  1. deto
    deto
    That's quite the compliment... thank you!
  2. 56sedandelivery
    56sedandelivery
    Too bad the intake's been mounted. A lot of guys drill a point in the manifold behind the carb mounting, and run a front breather on the fill tube. That works pretty well, and keeps things pretty hidden. There are several threads on it. But, there's always more ways to skin a cat, and you'll figure another way to do it. I've referred several guys from other sites to your thread, and the mounts/cross member you've made. It looks like the 51 Bus Coupe I gave to my nephew, and we built together, will be coming back to me; he just does't have the time or money now that he's started his own aerospace machine shop, and is remodeling the house we sold him from my Mother's estate. And he could't afford the car too ? Keep em' coming. I am Butch/56sedandelivery.
  3. deto
    deto
    Butch, the same thing p***ed through my mind about the intake. I could pull it, but my bigger concern is drilling it. I would prefer to leave it intact. The valve covers were cheap and are far from perfect. I think I can keep it pleasing to the eye by making the valve covers the point of entry...
  4. kidn1980
    kidn1980
    very nice brotha looking real good...wish i has skills like that...
  5. deto
    deto
    Thank you. I'm just taking my time and thinking how every step affects the next. I have had alot of positive feedback on this thread. Thanks again!
  6. deto
    deto
    So I decided to tap into the back of the p***enger side valve cover. It's "busier" back there by the vacuum can on the distributor, so I decided to keep all plumbing in one spot. Plus the p***enger side valve cover isn't as nice. Here's the baffle system I came up with, and then I packed it with breather material. Plans are to run a 90 degree rubber hose off the port to the manifold with a pcv in between.
    59IMPALER and slammed like this.
  7. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Nice work, it looks like it was ment to be there. I picked up a 58' 283 with a stock intake a while ago, now you've got me wondering how mine is setup.
  8. deto
    deto
    If it's stock, probably just a vented oil fill and a road draft tube
  9. Crazyolman
    Crazyolman
    If you have room I would still recommend a baffle to keep as much oil as possible off the intake holes.
  10. deto
    deto
    Will the holes and material not be enough? I can make a sheet metal baffle to go over it...
  11. deto
    deto
    More earth shattering progress...
  12. ss34coupe
    ss34coupe
    At least you are making progress! Keep it going.
    deto likes this.
  13. daddio211
    daddio211
    Great idea for the breather! Clean and simple too.
  14. deto
    deto
    So here's the pcv set up finished. I used a formed 90 degree elbow coming out of the valve cover. I'm going to add a 90 degree br*** fitting for the vacuum advance hose and that should wrap it up. I'm pointing at the inline pcv...
    kiwijeff and 62hotcat like this.
  15. deto
    deto
    The wife popped into the garage to drop this off! Very OT I know...
  16. 1950heavymetal
    1950heavymetal
    Nice work on the PCV install, very tidy and shows the quality work! I really enjoy the craftsmanship in your build and look forward to each update.
    Posted from the international space station
    deto likes this.
  17. drdave
    drdave
    Loving the well thought out idea you have going here. The PVC is quite impressive and sneaky. I'm not finding the sandwich OT at all...none of this happens on an empty stomach! ;)
    deto likes this.
  18. lowcoe
    lowcoe
    Um. Don't take this the wrong way but if you keep posting pics of your wife sandblasting then serving sandwiches we may have a problem... She's going to get a fan club.
    59IMPALER and daddio211 like this.
  19. deto
    deto
    The only thing worse than Chinese spreader bars are leaky valve covers... I took all the right steps to straighten the covers, peen the bolt holes out, glue the gasket, use black rtv... But I wasn't confident they would seal on the ends.
    Oh well. At least they're orange so it takes the edge off...
  20. deto
    deto
    Haha! I will let her know she's hambfamous...
  21. deto
    deto
    Prime time for crime time... And I spared no expense on my auto zone oil pressure gauge...
  22. deto
    deto
    Installed helicoils in 3 exhaust manifold bolt holes in the heads, installed the plugs and started laying out the wires. A little solvent and some elbow grease got rid of the branding on the wires. Laid 'em out in 2 different styles, but I think behind the valve cover looks best.
  23. deto
    deto
    Cut out these spark plug wire looms holders at work. Grommets will be in tomorrow. Gonna tig weld them to the valve cover spreader bars.
    daddio211 likes this.
  24. deto
    deto
    Got the grommets popped in and terminated the plug wires...
    kiwijeff, cretin and daddio211 like this.
  25. daddio211
    daddio211
    Clean! You should market those now that the hard work is done!
    deto likes this.
  26. deto
    deto
    Starter is hooked up, coil is wired with ballast resistor, all wires routed safely out of the way, freshly charged battery, and spark to the plugs, and a fire extinguisher near by. Gonna get fuel tomorrow and fire it up. Don't think the neighbors will appreciate an open header motor at this hour...
    kiwijeff and macdonald&co.garage like this.
  27. 1950heavymetal
    1950heavymetal
    You have great ideas Deto! The plug wire holders are great. Plan to take a video when you fire it up?
  28. deto
    deto
    Yes sir. It will be nice to hear it fire up. Hopefully that crate motor is as sound as it looked when I pulled it apart...
  29. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    You did a great job, I want to see the video of that thing roar to life!!
    deto likes this.
  30. deto
    deto
    Me too!
