Roadster body from scratch
Discussion in 'The Hokey Ass Message Board' started by Alf, Mar 16, 2008.
  1. Alf
    Alf
    I always wanted a model A roadster bodied hot rod, but after looking at the prices for even a rusted out pile of junk I decided to go a different route. I found a half smashed rusted out 35 Ford pickup cab and used the door skins, rear panel, and part of the firewall. I made a frame out of half inch tubing and planed to run it like a modified. Then I decided it would look way better with the rear deck and a trunk. So after making a template from a front fender, I proceded to make the frame work.
    Here is the fender I used for mock up and as a template.
    The first piece of the frame. I used a cinder block and a hammer to do the small radius bends and I cut slits in the tubing for the large radius. I figured two pieces for each side should work well. These are the outers.
    Copied the other outer for the p***enger side.
    Two inners.
    Finally set the inner pieces on the body.
    Then I tacked on the outers.
    Then I started adding bracing and forming the trunk opening.
    Once I got to this point I ran out of tubing.
    Top view.
    I clamped some sheet metal on there just to see what it looked like. Seems right.
    Thanks for looking I'll be sure to update you on the progress.
  2. tinmann
    tinmann
    Lord hates a coward. I think the original de-roofed RPU looked pretty good. You've got miles and miles of welding to do with your cut and paste method, surely you can find an inventive way of putting shape into the filler panels before installation. Even a sandbag would help. But keep up the progress.
    If you interpret my comments as negative, that's not how they were intended.
  3. Rich Rogers
    Rich Rogers
    as I see it, a ****load of vision, alot of planning and preparation coupled with alot of work and dedication. In other words, using what you have to build what you want. That's hot rodding. I like it, good luck with the rest of the build
  4. Hip
    Hip
    Right-on Alf! I like seeing the initative of the "doit yourselfer" (Doc Frank, plowboy, Hammerdebone), just to name a few. Looks cool to me. Can't wait to see the finished product. Press on!:D
  5. moefuzz
    moefuzz
    Man you do have a shnitload of welding ahead of you..
    You might want to take up hammer welding in order to keep distortion to a minimum.
    Good luck with your project and keep on posting...
  6. Hackerbilt
    Hackerbilt
    I'm not seeing it...yet anyway.
    I think your outer tubes should mount to the body lower...in the area of the cab reveal, and I also think the outer tubes need to be moved forward an inch or two, so that the rear of the body will have a roll to it. Right now the "quarters" and the "under trunklid panel" are almost straight across the back...pretty much a straight line.
    My 2 penny OPINION...and thats all its worth...is that you have the potential for a deadly little RPU and a cool bed would be a bit easier to fabricate with the tools you have available.
    With the good looks of that cab you put together, a RPU version would be AWESOME.
  7. GizmoJoe
    GizmoJoe
    Wow. Alf, you got guts.
    I agree with the others.
    You have a lot of welding ahead of you and a lot of desire.
    A nice rpu could be made quite easily and sold for a decent body to work with if you didn't want to keep it.
    Have you considered building an English wheel to help make some curved pieces to cut down on the welding? You don't need to spend hundreds to make a simple one.
    You certainly are doing it the old way.. with whatever you can find. :)
    Good luck and keep us posted.
  8. Outlaw Bender
    Outlaw Bender
  9. tfeverfred
    tfeverfred
    There are probably a hundred ways to do what you're doing, but I'm sure you know that and are proceeding. I commend you. I know what it's like to have a vision and not the finances to make it happen. Thinking I had to do it the way others did or that I needed a **** load of cash kept me from building a hot rod for 30 plus years. So I say, go for it, man. Do the best you can with what you got. Stay focused and see it through. In the end, the feeling of self worth will be worth it.
  10. Motorbreath
    Motorbreath
    Stick with it man, I can hardly wait to see more.
  11. scrape
    scrape
    how about using sheetmetal off a doner cars roof or something that already has the curves you need......
    good start though....
  12. thirty7slammed
    thirty7slammed
    from earth
    I respect a guy that comes up with a idea, and ain't afraid to tackle it.
  13. duste01
    duste01
    I once read an article about where a guy wanted a certain model of car, he didnt have any metal so he made it out of wood. It was real cool and had more hours than I would want to spend, but thats what he had. He sealed it instead of painting it, so you do with what you have. Its great to see someone doing something instead of wishing.
  14. JimA
    JimA
    Might need a couple extra coats of primer!
  15. 41 Dave
    41 Dave
    I say if you enjoy it - keep on doing what you are doing. Beats paying big bucks for an original body. Keep us updated on your progress.
    41 Dave
  16. Mudslinger
    Mudslinger
    Thats what its about right there!
    Good luck with your build.
  17. Al Napier
    Al Napier
    from Central CT
    Pretty nifty - I hope this works out for you :)
    Al in CT
  18. matt 3083
    matt 3083
    from Tucson, Az
    Go for it. The worst that can happen is that you gain experience.
    You are doing what i hope to be able to do in a year or two. Best wishes. PS I dream too.
  19. panhead_pete
    panhead_pete
    Have you thought about using hammerforms, PM FC Ute, he did something very similar with a car called "Miss Stickshift."
  20. David Totten
    David Totten
    Just think what you will learn from doing this project. Do it thats what Hot Rodding is all about.
  21. Bad Bob
    Bad Bob
    from O.C. Baby
    Seems like alot of work!
  22. kropduster
    kropduster
    whats the rear end? 4x toyota?
  23. 29 de soto
    29 de soto
    i admire the fact that your not afraid to do what you see fit.alot of guys get a hundred opinions and still dont have the backbone to get out the saw and welder!
  24. thewishartkid
    thewishartkid
    MAN!! THATS SO KOOL!!Hang in there it'll be GREAT when your finished, And all your handywork.
  25. Insane 1
    Insane 1
    from Ennis TX
    The experince you gain out of this endevor will be worth more than anything you could have bought.
  26. Hot Rodz R Us
    Hot Rodz R Us
    Show more pics. as you go, I can see the vision......
  27. if doing from scratch, you should do some real cool custom tweeks to the cl***ic design, make it known that every inch is kustom.
  28. Dyce51
    Dyce51
    from Ohio
  29. dude first thing you need to do is make your self an endlish wheel itll save you a zillion hours
  30. narducci
    narducci
    Keep up the good work, I am also building my own body but am using a bead roller and english wheel, but Im not a genius either!
