Hot Rods Roadster hearing protection
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 2, 2022.
  1. Blue One
    Blue One
    from Alberta
    Hey guys after 2 summers of fun in my RPU I have the bugs worked out and I’ve really been having fun.
    I’ve discovered that I prefer to run without the top and I’ve been looking into some technology to get some ear protection from the wind and exhaust noise and protect what hearing I have now.
    I’m considering a pair of noise canceling ear buds which will cancel everything above 85db.
    They’re a sporting type of earbud for shooting also.
    https://goaxil.com/pages/g***treme
    Have any of you guys tried anything like this.
    I like the idea rather than just using the regular foam ear plugs which for whatever reason can become painful for me to wear because of the pressure they put on my ear c**** from the foam expanding.
  2. saltflats
    saltflats
    from Missouri
    Looks like you would be smiling so big you would close off the ear cannels. :D
    I had a customer that used the noise canceling head phones. Not sure those would be the answer though.
    deadbeat, loudbang and Blue One like this.
  3. williebill
    williebill
    Don't know the answer to your question, but just wanted to say I really like your RPU. Well done! Love the Y-block, too!
  4. Budget36
    Budget36
    What’s the decibels of emergency vehicle sirens?
    Be the ****s to pull in front of a fire truck racing to the scene.
    Edit: I think it’s illegal here to drive a vehicle with headphones on for what I just mentioned.
    deadbeat, Hollywood-East and ClayMart like this.
  5. That's a good idea, although 85 db is still pretty high. Sure worth a try, though.
  6. twenty8
    twenty8
    Stop running the open headers when driving. Any ear protection helps you, but everyone else is still subjected to the noise. Open headers for on the track, and then you will have a helmet on, right???....:)
  7. Phil P
    Phil P
    harpo1313 and loudbang like this.
  8. vtx1800 and Just Gary like this.
  9. 210superair
    210superair
    from Michigan
    I've tried those when I was in loud bands in the past and did not dig it. Of course I'm half deaf in my right ear now from Marshall stacks screaming in my ear for 20 years, so there's that.
    Awesome vee-hikle you got tho....
  10. Blue One
    Blue One
    from Alberta
    85 db is the maximum noise exposure level for 8 hours of a work day that will not lead to hearing loss.
    That’s an OSHA guideline.
    wicarnut, 210superair and loudbang like this.
  11. If you drive fast enough you outrun the sound
  12. I use the foam universal fit units but if you want the next step up, there are fitted versions that are molded to your ears. The target shooters were the 1st I know of to use them. The company sends you the stuff to make the casting and then you send it back and they make the plugs. You are on the right track to protect your hearing. On a cycle, the low frequency noise isn't as noticeable but still very damaging in long term usage. I wore the foam units under my helmet for decades.
    Snicklefritz65 and ClayMart like this.
  13. DDDenny
  14. Blue One
    Blue One
    from Alberta
    These are earbuds that cancel extreme noise but still allow hearing at the same time so probably better even than earplugs and definitely not as isolating as headphones.
    I’m not interested in using them to listen to music or anything like that because that’s kinda defeating the purpose.
    Budget36 and lothiandon1940 like this.
  15. All jokes aside. my ears constantly ring.
    Work, loud rides, music…….
    ****s
    deadbeat, jimmy six and ClayMart like this.
  16. Mike VV
    Mike VV
    from SoCal
    These work great...from first hand experience..! Leight, MAX, corded ear plugs.
    https://www.mcmaster.com/earplugs/
    or
    https://www.walmart.com/ip/Radians-FP81-Deviator-33-Corded-Foam-Ear-Plug-NRR32/711002681
    BUT...you must use them correctly ! Just sticking them crossways into your ear...ISN"T the correct way. Roll them between your finger and thumb to make the foam smaller in diameter, Insert then "INTO" the ear c****, and hold them there while the foam expands.
    Not only have I used them on open ****pit cars, but for close to 400,000 miles of daily, motorcycle travel.
    Saved my hearing from wind noise..!
    Mike
    lake_harley likes this.
  17. Blue One
    Blue One
    from Alberta
    I don’t run open headers, my lake headers are plugged off and my exhaust runs through the frame and to the rear through Porter mufflers.
    5E309496-4050-426E-A08F-FF80E6888A6F.jpeg 9CBCAB40-D754-40BC-9EA2-A1FBB9EC4E73.jpeg
  18. dalesnyder
    dalesnyder
    That is one sharp ride,
  19. nitrobrother
    nitrobrother
    I've used these for years on Harley's and other open vehicles. Nice to just drop them down so they hang during stops, and they're in easy reach when it's time to get back on the road. At your local Wally-world.
    Jet96, 210superair and loudbang like this.
  20. indaworx40
    indaworx40
    from New York
    I agree about proper use. McMaster has a great variety. Rather than noise cancelling headphones, you might consider foam earplugs with a higher Db reduction value. Definitely cheap enough to try. I use the ones with 33Db reduction and can hear everything, including any emergency vehicle (hopefully not coming after me!). It's just muffled and a much more comfortable noise level.
    210superair likes this.
  21. Guy Patterson
    Guy Patterson
    The ones you show the link to my son uses and they are great. Get them and you will love them just my opinion from his usage around my loud cars and guns
  22. twenty8
    twenty8
    It is illegal in some places to use earphones/earbuds in both ears when driving. Even if it is allowed where you are, it is very unwise. Good to be using all your senses while out there a****st the rat race. Quietening down the exhaust a little is something you maybe should think about (and no, I am not "too old"). Losing your hearing is a huge price to pay just for trying to be cool..........
    Here are a couple of other options to reduce noise. One is way cooler than the other. Choose carefully..............:D
  23. y'sguy
    y'sguy
    from Tulsa, OK
    That is a sweet yblock!
    I would suggest trying the silicone swimmer's earplugs. You can shape into whatever fits. I use them for swimming, and they also cancel a lot of noise. I get them at my local drug store, Walgreens.
  24. Joe Blow
    Joe Blow
    I had a pair of those you listed. I didn't have any luck with them. They had a constant high whining sound when the sound amplify was on and to me they were somewhat lacking on really loud stuff (open headers). Contacted the company on the whining without much luck. They seem to be hit and miss on people really liking them and really not liking them. This was just my experience only though....and not saying they haven't worked well for folks.
    Here's reviews on them from Amazon.
    https://www.amazon.com/AXIL-Stryke-...t-reviews/B07VV63668?reviewerType=all_reviews
    I know you're not interested in foam but just FYI this is what I use.....the most comfortable foam devices I've used.
    Amazon sells them.
    dana barlow and lothiandon1940 like this.
  25. stanlow69
    stanlow69
    I drove a customers coupster back to my storage bay tonight. I just opened up my battery door on my in the ear hearing aids. It cancelled out all the noise.
    firstinsteele and catdad49 like this.
  26. gene-koning
    gene-koning
    WHAT??? DID YOU SAY SOMETHING? I WISH PEOPLE WOULD QUIT MUMBELING!
    I should probably get some kind of hearing aid/hearing protection, but I can't stand that stuff over or in my ears.
    wicarnut and Blue One like this.
  27. spudshaft
    spudshaft
    Couple of people sort of mentioned it, but check a motorcycle website or store near you
  28. BamaMav
    BamaMav
    from Berry, AL
    Tinitus. I have the same thing, probably from driving loud trucks and having the window cracked all these years. Some days it’s worse than others. It’s also inherited, my Mom and sister both have it also, and neither have been exposed to as much loud stuff as I have.
    I can wear a headset, but can’t stand ear plugs. I can put a set in, and I’m staggering around like I’m drunk, they screw with my balance somehow. At one place I used to load they required us drivers to wear ear plugs, I couldn’t do it. After I staggered around and about fell under a fork lift, they decided it was better if I didn’t wear them. Wasn’t long after that they quit requiring them. Didn’t need them anyhow, we were outside, 100’ away from the machines running inside the building.
  29. gimpyshotrods
    gimpyshotrods
    I know what a roadster is, but what is this hearing thing you guys are speaking of?
  30. I'll have what Johnny's wearing! (after all, he was known for his fashion-sense)
    twenty8 likes this.
