Roadster mirrors...lets see em
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Jan 29, 2005.
  1. Toqwik
    Toqwik
    Trying to figure out what kind of mirror I wanna use in my 28. Was thinking dsah mount, but I think with the rake it will be of little use. Maybe hang one off the side of the car, any ideas???
  2. Model A Vette
    Model A Vette
    I've used post mounted mirrors for right and left sides. The first set were from some unknown source converted from clamp-on to threaded. Once the chrome got too brown I went searching for replacements. I got two for $10 from a closeout bin at the motorcyle shop. They came threaded for "late" bike handlebar mount. The ones for Jap bikes are usually 10 mm threads.
    I first used a supposedly stock style inside mirror which mounted over the top of the windshield frame. It changed vibrating frequency with the engine revs. It was very annoying. I changed to a small gl*** mounted mirror from a Vega or Monza. It is a day/night mirror which is a plus. It is quite small and black so it doesn't shout "LATE MODEL".
  3. flatheadpete
    flatheadpete
    from Burton, MI
    I used a bicycle mirror bent to see...
  4. Mirrors, I don't need no friggin mirrors, I am an owl. Hey all kidding aside, I have seen a unit that clamps over the top of the windshield. I can't remember where, but you might try Speedway, they usually have most of that stuff.
  5. Deuce Roadster
    Deuce Roadster
    I used a threaded post on the whinshield stachion.
    :rolleyes:
  6. Attached Files:
  7. Hapydz
    Hapydz
    Just before Total Performance was taken over by Speedway, I ordered a set of neat 3"dia. staight arm screw in mirrors for my roadster. Well, I never did get them and Speedway does not sell them. Anyone know of who might have them as I can't find them anywhere. HELP!
    Ron
  8. denis4x4
    denis4x4
    from Colorado
    Went with spun aluminum British sports car mirrors as they matched the aluminum sprint car steering wheel.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    They are most likely stock 28-31 Open Car Post mirrors, usually sold as A-17700-P or maybe the B-17700-P which fits 32 open cars.
  10. 4woody
    4woody
    I like hinge pin mirrors 'cause I don't want to make holes in my body, and it is a nice clean mount. Since you are a Ford guy you can probably get ones that fit your hinges.
    Since mine's not a Ford I'm working on adapting VW hinge pin mounts. VW made several versions and shapes that could look good on an old car.
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    We used 2 new 35-36 Ford Pickup taillamp brackets on the Track Roadster. The spacing of the mounting bolts matched the holes in the T windshield frame and after cutting off the extra eye on the bracket for the taillamp we had a nice clean bracket to mount out 4" round mirror heads.
  12. fergenboysinc
    fergenboysinc
    Chopped mine of my Hog. kinda big...but, you can see stuff behind you.:rolleyes:
  13. Mike Miller
    Mike Miller
    I took a set of mirrors off a Honda Mo-Ped, threaded the shafts, drilled and tapped my W/S posts and screwed them in.
  14. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Mine mount on some small aero tubing that I made to both hold the mirrors but also hold in the wind shield sections.
    Rex
  15. Deuce Daddy Don
    Deuce Daddy Don
    I used a Harley Davidson (1972) for drivers side, made my own 3/8 round stock arm, heat & bent it on desired angle, threaded one end to screw into windshield frame, & had it chromed, use a 3/8 lock nut & washer.
    For rear view windshield, have local gl*** shop glue mounting part to desired area in top center, mount mirror of choice.
  16. Cut down Harley mirrors on both my roadsters.
    J&P Cycles sells these, good quality and a good outfit to deal with.
    The Harley mirrors work quite well and beat the resto-style 32 mirrors all to heck and gone in the useful dept.
    Plus, you can find Harley mirrors almost anywhere . . . you may be able to find a pair of "take-offs" from a Harley rider who sprung for a different pair for his bike.
    Hacksaw, file and die will do it for setting these up.
    Make sure you run the die on straight, easy to get them canted and then the threads don't look or work right.
    This is the wrong Harley mirror -they have lots of different styles.
    It could work for some, but didn't look right on my 31.
    Shown here due to the different mount right on the 31's "A" windshield stanchion and replaces one of the mounting bolts.
    I have 32 windshield posts on the 31, but like the stanchion mounting on this car better.
    The door does miss the mirror by a good amount.
    Left side, good view, good quality gl***.
    Right side 32
    Not too obtrusve.
    Mirror screws into the threaded 32 posts.
    Here's the same mirror on my pal's 29.
  17. 972toolmaker
    972toolmaker
    from Garland Tx
    I use 1937 ford mirrors on my hot rods 10/32 thread on the ball make my own base to glue to windshield.have a machinist buddy make it.everyone who builds has to have that guy ,welder painter etc.
