roadster... part 1
Discussion in 'The Hokey Ass Message Board' started by Yaril, Jul 31, 2008.
  1. Yaril
    Yaril
  2. Yaril
    Yaril
    thanks to the recent B*** post i got an idea to modify the front cross-member in order to lower the radiator. im looking for 4" but only got 1" from what i did. i am hoping that the new 29 shell i ordered (it being wider than the Chevy shell on the car) will sit lower on the radiator. its a repop steel shell so i can tweak it if need be. it should be here next week.
    original cross-member, see how the rad sits up higher:
    modified cross-member, also flipped the U-bolts so they point down, now the rad sits just on the u-bolts:
    any other ideas?
  3. Yaril
    Yaril
    trying out imageshack instead of photobucket. well, here are some more pics of the radiator changes...
    rad sitting on modified cross memeber formed to lower rad 1"
    new shell i purchased in bare steel
    plans are to "pancake" the rad shell top to better flow with the 30 cowl top
  4. WelderSeries
    WelderSeries
    Alliance Vendor
    Yaril, I just saw this thread... looks great!
    dw
  5. Yaril
    Yaril
    thanks DW! hey ima call you today or tomorrow about a front pan-hard bar.
    finished "pancaking" the rad shell. i think it worked out great. i lapped the top to add a raise around the filler neck. filler neck still needs to be lowered it pokes to high.
  6. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I thought you were getting rid of this car? I am glad you are still plugging away at it because I love this thing! You really have done this car justice.
  7. Yaril
    Yaril
    jeff, i still want to sell it, cause i got other projects in mind and need the space / money. regardless of when those projects take shape i do enjoy this car and will continue to plug away at it to make it what i want till the day somebody wants to take over.
    thanks!!!
  8. Yaril
    Yaril
    hey anyone have a good grill idea? something i can make preferably?
  9. Yaril
    Yaril
    shell is done, mounted to the rad which is mounted to the cross-member. going to respray the shell cause the red oxide is a bit off, no biggy.
    flows nicely wit cowl top. still need to section a piece of the radiator fill neck...
    close up of the lap i made on the shell. its roughly smoothed out all in metal. im sure a couple more tack welds and smoother grit grinding would make it look almost factory...
    top of shell is almost perfect with top of cowl. huge improvements to where it was before.
    think i will make the rad support bars where i placed the blue tape. my other thought was to go from the center of the rad shell down to each valve cover.
    also just got my F-1 shock brackets and front & rear pan-hard bar. stupid question but i have never had a front pan-hard bar, should the front and rear bar be mounted the same side ch***is, same side suspension?
  10. WelderSeries
    WelderSeries
    Alliance Vendor
    We've always mounted the frame end on the drivers side, on both the front and rear kits.
    Looks awesome, Yaril!
  11. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Tires look rad my friend. I can tell you how much that improved on the car.
  12. Yaril
    Yaril
    thanks DW, will be installing those great looking pan-hard bars today. should have some pics by earning.
    i hear ya Jeffrey!
  13. Yaril
    Yaril
    some updates...
    front and rear pan-hard bars are done thanks to DW for the great parts! brackets worked out great and the bars were the perfect length.
    front bar:
    rear bar:
    also finished up the new front shocks / headlight brackets. cut and welded the F-100 shock brackets to 90 and added a mount for the headlight next to it. i blended most of the welds and sprayed it black. mounted the lower shock to the bone too. its a much cleaner look now.
    also went ahead and did rad support bars. simple bars made to fit from the cawl to the shell. painted those black as well.
    car has really come a long ways. got a rear view mirror for it too. here are some overall pics to compare from day 1 till now...
    thanks for looking.
  14. You've done a really great job. I've enjoyed following along. Can't wait to see your next projects.
  15. Flatheadguy
    Flatheadguy
    I think your car looks great as-is. It's a little new, a little old school and damn sure cool!! Plus, it's one-of-a-kind and got personality. Don't be anxious to change it unless it's what YOU want it to be. Advice and opinions are nice, but don't count votes...use your own.
  16. WelderSeries
    WelderSeries
    Alliance Vendor
    Looks really really good, Yaril. Should be a fun car!
  17. Yaril
    Yaril
    thanks guys!
    changes are all based on what i thought the car should look like. i reference the Tardel book for a lot of the brackets and what knot. finally drove the car today and its tight. i like it, very responsive and takes bumps well. Thanks DW for the parts! love to work with new fresh parts.
    today i am working on making a cross bar betweent the 2 shock mounts that will be slightly curved. last thing to do will be the grill itself. going to go with 3/16" round bar for a frame and 1/8" bars as vertical bars with maybe 1 horizontal for support. will paint it all gloss black and set it on the shell from the front via a few studs through the shell.
  18. Mr. Weld
    Mr. Weld
    Car looks awesome, love the wheel and tire change..
