Technical Roadster shock mounts
Discussion in 'Traditional Hot Rods' started by sdroadster, Dec 21, 2023.
  1. sdroadster
    sdroadster
    P1000862.JPG P1000858.JPG P1000860.JPG I have used this shock mount design several times, it is cheap, works well on fender less cars, and is a DYI project. It's sturdy, and leaves people saying why didn't I think of that.
    These are Speedway bolt on shock mounts. The back of the mount has a round tapered area designed to fit into the lower part of a wishbone.
    1. I made a tear drop shaped piece of material, and used a hole saw, so the material would fit over the round tapered area on the back of the shock mount.
    2. Figure out the shock mount position rotationally, and electric weld the material to the shock mount.
    3. I used a piece of tubing to reduce the size of the mounting hole from 1/2 to 3/8, and drilled a corresponding hole in the frame in the proper location.
    4. Drill a 5/16 hole in the teardrop material and bolt it to the frame. This keeps the shock mount from trying to turn based on the shock absorbers effort.
    5. I made a little round insert to fit in the shock mount. I will probably JB Weld it in after everything is tight.
    6. These are 50 Plymouth front shocks, available on Rock Auto for $16.00 each.
    Here are some pictures.
    alanp561, Jibs, mad mikey and 16 others like this.
  2. AngleDrive
    AngleDrive
    from Florida
    Very simple and ingenious
    mad mikey likes this.
  3. X-cpe
    X-cpe
    Clean piece. Is there enough room to weld a nut on top of the 3/8" bolt and use matching ****on head bolt to retain the insert?
    alanp561 likes this.
  4. sdroadster
    sdroadster
    That's a good idea. I'm thinking drilling the head of the bolt a bit, and tapping it to 10-32
  5. Bandit Billy
    Bandit Billy
    I like it! But about that pusher fan...
    alanp561, DDDenny, mad mikey and 3 others like this.
  6. chickenridgerods
    chickenridgerods
    from DSM, IA
    Clever idea.
    I would not JB Weld the plug into the mount, though. When the day comes to remove the mount whomever has to do it will be cursing you. I'd suggest something such as a set screw drilled through the bottom non-visible side of the mount.
  7. Bugguts
    Bugguts
    Very cool idea and very clean looking!
    The ingenuity shared on here amazes me.
  8. ronzmtrwrx
    ronzmtrwrx
    Nice. Clean and simple.
  9. mad mikey
    mad mikey
    Neat idea, I like it a lot. Has a cool old school vibe as well. Nicely done.
  10. Happydaze
    Happydaze
    I really like those mounts, and I also like and indeed have some very low mounts. I have a concern however and that's the shock length. On mine I have the P&J open short shocks. They've been in service for over 20 years now and are as far as I'm aware doing fine. A few years ago I got some short Bilsteins as I understood the ride to be transformed with them. The problem I encountered was there was no upward travel available, the short shocks weren't short enough. I have Bilsteins front and rear on another 32 and they ride beautifully. So the message is be prepared to find some short shocks with low mounts, sounds kinda obvious really, or perhaps it's that all 'short' shocks are not created equally!
    Chris
  11. sdroadster
    sdroadster
    I like hand made things. In think that's what draws real hot rodders in, and why we walk past the magazine cars. If you look at the first picture in this thread, you can see the reversed firewall in the photo. I gained about 10 inches of leg room in this roadster pick up by moving things around, and avoiding the main stream logic. Hell, I bolted a Studebaker body to a Chevy S10 frame, and with a used motor went 221 mph at the Bonneville Salt Flats. Filter out the nay sayers, and follow mechanical logic and design.
    alanp561, X-cpe and Fordors like this.
