Technical Roadster windshield
Discussion in 'Traditional Hot Rods' started by Rocket88NZ, Nov 14, 2025.
  1. Rocket88NZ
    Rocket88NZ
    Just finished making the windshield for my roadster, can't take credit for the idea as I used youtube example to do it. Pretty happy with the results and have just got the gl*** in and mounted on the car. Used 1/2" water pipe and machined the slots for the gl*** on the milling machine. On the bottom of windshield left 4 small ares unmachined so it wouldn't open up when bending it, then used cutoff wheel to remove these after bending. P1140255.JPG P1140256.JPG P1140257.JPG P1140258.JPG
  2. alchemy
    alchemy
    I need to do the same thing for a project of mine. I’m too cheap to buy a repro frame just to cut it up beyond recognition.
    Did you use setting tape when you mounted the gl***, or urethane?
  3. Rckt98
    Rckt98
    Great stuff Mike. The roadster is really starting to look the part.
