Projects Rob Bobs 1932 truck part 2
Discussion in 'Traditional Hot Rods' started by rob bob, Nov 14, 2014.
  1. rob bob
    rob bob
    from Canyon TX
    That's pretty cool!
  2. rob bob
    rob bob
    from Canyon TX
    Thanks man!
  3. Okie Pete
    Okie Pete
    WOW amazing build , so many hand made parts , pieces , brackets that have function and beauty . Kool machine Hot Rod.
  4. 1-SHOT
    1-SHOT
    from Denton
    Looking good, I can appreciate all the work you did to make it slick. Frank
  5. Rand Man
    Rand Man
    Awesome. I'll take all the pant and body tips I can get
  6. Rem
    Rem
    That's a great little pickup, and as the others have said, thanks for posting the build details and the paint how-to. One question on the priming: you say to make the first coat of four 'dry', but how dry? I'm a complete paint novice but it seems to me that if too dry you won't get a good key/bond to whatever is underneath. I know you don't mean literally dry, but how do you gauge it?
  7. rob bob
    rob bob
    from Canyon TX
    Basically don't try to get full coverage on the first coat hold the gun the same distance you normally would just move a little faster. The picture where I put the first coat of top coat sealer on my grill shell is what your going for. ImageUploadedByH.A.M.B.1456422375.461563.jpg And you can see how it's fully covered on the second coat. ImageUploadedByH.A.M.B.1456422865.294069.jpg
  8. Rob, I started reading in your original thread on the cab. It vanished and I got busy. I don't check in here very often so when I saw your thread, it was an accident. Because I know what you started with, I can say you did well. :) Because I'm an old guy, I want to pass something on to you. You have mentioned the budget aspects of your build repeatedly and I understand and agree with all of that. The biggest favor you can do for yourself is to put the expensive clear on your stuff. It will save the lower cost base coats in the sun for a long time. If your truck will be in the garage most of the time, none of this will matter. Best of luck with the remainder of your truck. :)
    mrobvious34 likes this.
  9. rob bob
    rob bob
    from Canyon TX
    We have had pretty good luck with this clear I've seen it last over 10 years on a car that's been sitting outside every since the day we painted it, most factory clear coats wont do that. Other than the occasional road trip and near daily driving my truck will be sitting inside the shop so It should last a very long time. But I do understand what your saying I've since found a affordable HS clear that I really like and will most likely use on the remainder of my truck.
  10. AmishMike
    AmishMike
    Great job - thanks for all the paint info. One key question for us northeast painters - what was the temp & HUMIDITY when you were painting in Texas????? Always afraid to try black. Usually paint in the summer which can mean high humidity & temp.
  11. RodNoc
    RodNoc
    from Kelso, WA
    Im always impressed with what a single individual can accomplish with some serious TALENT. Im jealous. Subscribed
  12. rob bob
    rob bob
    from Canyon TX
    I have actually painted a lot without a booth in all types of weather. It can be done. In the winter just allow extra time to dry and I've painted in summer with high humidity as well with no problems. After my truck is done ill be adding on to the shop for a new paint booth. I might add I use mid temp activator year round.
    AmishMike likes this.
  13. rob bob
    rob bob
    from Canyon TX
    I got a few more little parts painted this week. ImageUploadedByH.A.M.B.1456696253.504448.jpg This dash was just full of little rust pits, 3 coats of slick sand and blocking filled all the little pits then three coats of 2k primer and it was ready for final sanding and paint. ImageUploadedByH.A.M.B.1456696455.052613.jpg Dash painted and cleared. ImageUploadedByH.A.M.B.1456696544.430176.jpg Same with the headlights slick sand, block, 2k prime, sand and paint. ImageUploadedByH.A.M.B.1456696653.124415.jpg Same thing as the grill I'll be spraying a flow coat on the headlights an dash. ImageUploadedByH.A.M.B.1456696741.019829.jpg ImageUploadedByH.A.M.B.1456696768.837355.jpg ImageUploadedByH.A.M.B.1456696805.528596.jpg Now after the flow coat. ImageUploadedByH.A.M.B.1456696872.007432.jpg ImageUploadedByH.A.M.B.1456696916.108354.jpg Flow coat adds depth and a really nice wet look. ImageUploadedByH.A.M.B.1456697114.486396.jpg That's all for now I have most of the body work done on my drivers door so I'll be doing step by step instructions on that later on. Thanks for looking!
    kidcampbell71, cfmvw and Rich B. like this.
  14. Paint looks SLICK ! Do you find you get much trash in the paint, without a booth ?
  15. Eric1967
    Eric1967
    from Union, Mo
    Looking good. I appreciate the paint tech.
  16. AmishMike
    AmishMike
    Tks much for info - do the wet floor thing also. Beautiful paint job...
  17. rob bob
    rob bob
    from Canyon TX
    It all depends on the conditions that day, yes most of the time we get dirt in the paint but we just color sand and buff it out.
  18. Scott Mannion
    Scott Mannion
    from Scotland
    Loving the quality of your work not to mention the speedholes.
  19. Scott Mannion
    Scott Mannion
    from Scotland
    More speedholes - superb!
  20. dmorago
    dmorago
    Your work is inspiring; setting new goals and horizons for many of us. As Albert Einstein once said, "Example isn't another way to teach, it is the only way to teach." Thanks for sharing, Dick M
    rob bob likes this.
  21. Mart
    Mart
    The quality of the paint is fantastic!
    Great work.
    rob bob likes this.
  22. LTM75110
    LTM75110
    That`s some shiny stuff,Looks good...
  23. mista
    mista
    from Finland
    Not the easiest color to deal with and you make it 10+
    Sent from my C6603 using H.A.M.B. mobile app
  24. rob bob
    rob bob
    from Canyon TX
    It's funny cause I hate everything about black when it comes to a daily driver. But all throughout the build I knew it was going to have to be black, so it's a love hate relationship.
    Sent from my LG-AS730 using H.A.M.B. mobile app
  25. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
  26. Bader2
    Bader2
    Black and beautiful!
  27. Barn Find
    Barn Find
    from Missouri
    That's come a long way.
  28. rob bob
    rob bob
    from Canyon TX
    Got a few more parts painted up! ImageUploadedByH.A.M.B.1459912558.759845.jpg ImageUploadedByH.A.M.B.1459912591.138566.jpg ImageUploadedByH.A.M.B.1459912616.074293.jpg ImageUploadedByH.A.M.B.1459912640.866896.jpg This is a new clear I've been using that's claimed to be a 20 year clear. ImageUploadedByH.A.M.B.1459912774.584480.jpg ImageUploadedByH.A.M.B.1459912806.728446.jpg ImageUploadedByH.A.M.B.1459912841.530003.jpg ImageUploadedByH.A.M.B.1459912876.660811.jpg ImageUploadedByH.A.M.B.1459912902.073349.jpg
  29. rob bob
    rob bob
    from Canyon TX
    Also got the firewall painted. ImageUploadedByH.A.M.B.1459913151.597296.jpg ImageUploadedByH.A.M.B.1459913171.569355.jpg ImageUploadedByH.A.M.B.1459913193.098530.jpg
    1952B3b23 and kidcampbell71 like this.
  30. rob bob
    rob bob
    from Canyon TX
    More updates coming soon. I apologize for not going in depth on the previous paint and body work I've been extremely busy if anyone has questions I'll do my best to answer them. Thanks for looking!
    Runnin shine likes this.
