Rochester 2 Jet double check
Discussion in 'Off Topic Hot Rods & Customs' started by OWes21, Dec 31, 2025.
  1. OWes21
    OWes21
    Can anyone confirm this is a large base?
    I'm new to carbs so excuse my ignorance.
    From what I have read and measured they seem to my large base instead of small.
  2. jimmy six
    jimmy six
    Show us the base…it how you know!
  3. OWes21
    OWes21
  4. studebakerjoe
    studebakerjoe
    The base. Not the bowl. If I recall correctly bolt pattern on base is about 2x3 3/4 center to center.
  5. OWes21
    OWes21
    Sorry like I said I'm new to all this. When you say base I think the bottom of the carb
  6. studebakerjoe
    studebakerjoe
    Yes. Exactly, the bottom of the carburetor.
  7. studebakerjoe
    studebakerjoe
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    studebakerjoe likes this.
  9. OWes21
    OWes21
    Okay, that was the bottom of the carb
    I'm working on a tri power
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    we need to see the base
  11. OWes21
    OWes21
    I think I'm not follow on base. You said base of the carb which I ***ume is the bottom and that's what I sent. So now I'm ***uming you meant the base plates under the carbs which are these
    SS327 and down-the-road like this.
  12. OWes21
    OWes21
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    those look like small base, you need to measure
    The name "big base" refers to the bolt pattern.
    The big being 2" x 3 3/4" bolt hole center to center.
  14. OWes21
    OWes21
    Okay I'm not follow in which bolt pattern because there is a few places to measure off of.
    I'm a visual person
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    the bolts that hold the carb to the manifold
  16. BHRS
    BHRS
    from Texas
    The first pic clearly shows a small base 2G with a truck manual choke top. 55-58 were front fuel inlet and 59-73 side inlet like one pictured. 55-68 no numbers stamped on the right front 69-73 were stamped. Avoid later ones as lots of air bleeds for leaner mixture and emissions requirements. I build custom tri-power sets with small base Rochesters. Reach out if you have more questions.
    Link to one of my vintage induction systems for reference. https://www.jalopyjournal.com/forum/threads/custom-rochester-2g-tri-power.1322343/#post-15382749
  17. carbking
    carbking
    Wes - there are three major castings used on the Rochester 2G series carburetors.
    From top to bottom:
    Airhorn - commonly referred to as the top.
    Bowl - commonly referred to as center section or main body
    Throttle body - commonly referred to as the base
    There are two COMMON mounting patterns of the non-Ford two-barrel carburetors.
    "Small" measures 1 7/8 inches front to rear, and 3 1/4 inches from side to side.
    "Large" measures 2 inches front to rear, and 3 11/16 inches side to side.
    What is being measured is the center to center distance of the bolts holding the throttle body to the intake manifold.
    Jon
  18. OWes21
    OWes21
    Thank you everyone!
    I wasn't aware the base plates were considered part of the carb. I have been measuring the three bolt holes on the actual carb.
  19. OWes21
    OWes21
    Appreciate the information! That is a beautiful set up you built.
  20. jimmy six
    jimmy six
    If it wasn’t part of the carb you thought an engine would run without it?
    SS327 likes this.
