Rochester 2 jet identification Q
Discussion in 'The Hokey Ass Message Board' started by Scott, Nov 19, 2009.
  1. Scott
    Scott
    I am rebuilding a rochester 2GV I can't tell what year it is. It came with a rebuild kit GP Sorensen 96-111D I have tried to cross reference the # but to no avail. Any help would be helpful
  2. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Oh man....you a Buckethead,too? Hoo hoo....anyway, grab your wire brush and give us the number off the side of the carb body...then we can tell ya what it is. There were so many of those little ******s made....thats the only way to really tell....
  3. 96 111 is for 2gs
    covers almost all of them
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If it doesn't have a number stamped in the p***enger side of the fuel bowl, it's pre-1968. The problem with the '67 and earlier 2 bbls. is that when someone threw the I.D. tag away, it made it just about impossible to identify it. Does it have the choke thermostat on the air horn? If so, it's '63 or earlier. If it uses a divorced choke (thermostat spring in the intake), but doesn't have an I.D. number stamped in it, it's '64-'67.
  5. Scott
    Scott
    It has a # stamped in a circle on the side &031770 ( the& represents a number I cant read but I think it should be a 7)so 7031770
  6. Scott
    Scott
    One more 2 jet question, there is a fuel line that comes out the bottom of the float bowl, is that an overflow or a fuel return or some kind of vent
  7. manyolcars
    manyolcars
    NOT a fuel line
    it was a vac*** line
    plug it and use full manifold vac***
  8. Scott
    Scott
  9. tommy
    tommy
    Actually that vacuum port is connected to manifold vacuum. It goes straight down through the carb body ligning up with a hole in the carb base that opens up to the cavity below the throttle ****erflies....manifold vacuum. That is where GM hooked up the vacuum line for the vacuum advance but it is still full manifold vacuum. Yes GM distributors were designed for full manifold vacuum. Leave it unplugged and it won't run. You'll have a m***ive vacuum leak. Some of them were steel hard line and others use a rubber hose. It goes into the carb above the ****erflies but it connects to manifold vacuum below them.
  10. shadetreerodder
    shadetreerodder
    The 2g series of rochesters all use the same basic rebuild kit. The next letter in the line up denotes the style of choke ***ociated with that particular carb. Some were operated by a bimetal spring whle others are either water or manafold heat control and then finally manual. Charlie Price at www.vintagespped.com sells rebuild kits for them and ***ociated replacement parts.
