My Rochester 2 jet looks like it is leaking from the throttle linkage where it goes to the blades it there anyway to fix that?
Replace the needle and seat and set the float to spec. Check the throttle shaft for excessive play and wear.
These carbs have an issue with the fuel getting hot after shutdown and boiling out of the throttle shaft hole, especially with modern fuel. If that's the case, try to reroute the fuel line away from exhaust components, or shield it from heat somehow, and add a phenolic spacer under the carb to disperse some heat from the carb base. If it's leaking while running, then you've got too much fuel pressure or the float isn't set correctly.
I found the problem I put a rubber gasket on the the venturi screw instead of the fiber one and it tore just letting it leak onto the blades thanks for the help gentlemen
