rochester 2 jet question
Discussion in 'The Hokey Ass Message Board' started by Flat-Foot, Oct 30, 2011.
  1. Flat-Foot
    Flat-Foot
    from Locust NC
    Can someone tell me what this vac*** port is for (right under choke cable)? Not sure if I should plug it or if there should be a line there. This is the stock carb on my buick 198 v6
  2. carbking
    carbking
    Original vacuum source for original automatic choke (now missing). Plug it.
    Jon.
  3. latham
    latham
    from Michigan
    Your 2G carburetor originally had a hot air choke housing, coil & cover mounted to the air horn. The function of the vacuum port (in question) is to draw hot air through the housing to heat the choke coil. Since you're using a manual choke cable, you should plug the vacuum port and readjust your idle mixture & idle speed. Currently, the ports only function is to create a vacuum leak and disrupt idle quality.
  4. Flat-Foot
    Flat-Foot
    from Locust NC
    Thanks guys! I have been searching for that leak for a while. It only took a buddy about 5 seconds to find it yesterday. The car definitely runs a lot better now.
  5. MalibuKasey
    MalibuKasey
    Thats how I roll!! I need your address for the bill! Glad we found it.... It was annoying :)
  6. Flat-Foot
    Flat-Foot
    from Locust NC
    Yeah I will get right on that!
