I never ended up using this kit for my tri power build, so it’s time to let this go to someone else. Part number 91011589 from Speedway. Kit includes: Gaskets Secondary power valve plugs Primary power valve Primary modified power piston Primary throttle shaft Primary throttle plates Primary throttle shaft Jets for all 3 carbs Aluminum secondary bases Progressive linkage Instructions
