Rochester 2G carbs
Discussion in 'The Hokey Ass Message Board' started by Camm, Jul 11, 2008.
  1. Camm
    Camm
    What should the fuel pressure be on 3x2 system for a 283 ??????? Thanks:confused:
  2. BigChief
    BigChief
    4-6 psi should keep the 2G happy.
    -Bigchief.
  3. Koz
    Koz
    Anything over four pounds totally screwws up my trips, (2GC Rochesters on an SBC, Offy intake. This is a pretty serious Chevy too. I,ve never had fuel starvation problems even in the quarter. Make sure you gauge pressure at the carb level.
  4. Camm
    Camm
    That's what i was thinking 4 lbs.
  5. blackout
    blackout
    Yea use a regulator and go for @ 4-4.5 lbs. They will likely leak above 5 lbs. At 5.5 lbs, the floats were pushed up enough to cause a rich idle, I had to "clean it out" like a race car after sitting at a red light.
  6. I installed a Holley 12-804 regulator and run the factory setpoint of 2.7 psi on my trips and I have plenty of fuel when it's needed.
  7. tommy
    tommy
    I've had a hell of a lot of 2GCs over the years on mechanical and electric pumps and never had a regulator of any kind. I can't be that lucky.
  8. willowbilly3
    willowbilly3
    from Sturgis
    I was thinking about the same number. I have put those clicker regulators on and just turned them down to see where an engine would starve at. I actually ran my 300-6 F250 at about 1.7 because it ran and gave me no problems there.
  9. Abomination
    Abomination
    It slays me these guys running 8 - 10 PSI...
    ~Jason
  10. Uncle Big Bad
    Uncle Big Bad
    Not to steal the thread, but I'm running a single 2g on a flattie. Where should I set my regulator at?
  11. Abomination
    Abomination
    4 - 6 PSi should be fine. :)
    I say start at 4 PSI and play with it. The goal is to get only as much fuel as you need at speed.
    ~Jason
  12. 1929rats
    1929rats
    Ive kept mine at 4.5 for the last 3 years with zero problems
