Rochester 2GC carbs
Discussion in 'The Hokey Ass Message Board' started by Jimv, Sep 2, 2007.
  1. Jimv
    Jimv
    I'm running trip's on my car , 2 secondary carbs are older Rochester 2 barrels(1967) center one is a little newer( 1969) I'm wondering what my total CFM is?? Its a 400 CI SBC(Stock), it is under carbed?
    JimV
  2. jobob
    jobob
    No about 800 to 900 cfm just fine Jobob
  3. LowFat48
    LowFat48
    I believe they are 273 cfm each ......
  4. it depends, are the front feed (with a big filter nut) or side feed.
  5. Jimv
    Jimv
    there all side feed
  6. yekoms
    yekoms
    All of the small (side feed)2GCs that I had on the flowbench flow between 250-270 cfm.
    That's with the small chrome louverd air cleaners with K&N elements.
    The common chrome louverd air cleaners are VERY restrictive!
    To fix that problem put a spacer on top of the element to lift the "hat" up about 3/8". That opens the small gap up around the bottom of the hat.
    The rubber seal from a Fram HP4 oil filter works great as a spacer.
    Do you know what I'm sayin'?
    I can do some pics later if they would explain it better.
    Have fun,Smokey
  7. Chuck R
    Chuck R
    How do you identify which Rochester 2 jet carb you have? I have looked mine over and the only # I see is 7000285 on the bottom of the float bowl. They all have the same number and are set up on a progressive linkage. They work very well but I need to get some rebuild kits and am not sure exactly which model they are. This engine has been together for almost 40,000 miles. Sorry it looks so beat.
    Thanks in advance
    chuck
  8. vintakes
    vintakes
    your probaly ok with cfm here depending on other motor mod gearing etc the GM fact 3x2 in 59 [except for chevy] went to the larger ends and smaller centers 350 cu - 400 cu i believe some later 60's gto"s and pont 421 HO's came with all large rochesters bottom line your 400 if modified would perform better with the larger ends and maybe with the larger center carb i've seen some offy 3x2 large bolt intakes around maybe try one and file the small center carb base mounting holes out to fit the larger pattern john
  9. yekoms
    yekoms
    Copshopcoupe, I looked on the sheet that came in the rebuild kit for the 2Gs that I have.(Standard Motor Parts "Hygrade" Brand)
    Your number is not there. Most of the numbers start with 70 but higher than yours. The closest is 707171(55 Chevy truck)
    It ain't much but,I tried. Smokey
  10. Chuck R
    Chuck R
    thanks, I will keep looking. I am going to try a local guy who rebuilds carbs and see if he will give up any info.
    Thanks
    Chuck
  11. falfa1955
    falfa1955
    Hi.....I have a Man-A-Fre 4X2 intake manifold for a big block and want to find the kits for the carbs. All 4 are Rochester 2GC, and have the number 7011824 on the main body. Does anyone know the source or part numbers of the kits or where I can buy them...thanks guys:):):)
  12. inline 292
    inline 292
  13. demmals7ytriht
    demmals7ytriht
    from Speer lane
    Thanks in advance
    chuck
    If there small base rochesters the kits are pretty much universal. I recomend doing a search on Vintage Speed, it's a mom and pop shop, Charlie can answer any questions you got, good people to do business with.
  14. ADReese
    ADReese
    from spokane
  15. PontiacRoss
    PontiacRoss
  16. Mr48chev
