Rochester 2GC question
Discussion in 'The Hokey Ass Message Board' started by 48stude, Feb 13, 2010.
  1. 48stude
    48stude
    I'm curious what these small ports are for in the base of these two barrel rochesters? They're above the throttle plates. Are they to lean out the mixture? Thanks , Bill
  2. 48stude
    48stude
    Forgot the pics.
  3. I dont think those are factory. I have several dozen of those carbs and none of them have holes in that location. You guess is as good as any why they drilled them:confused:
  4. 48stude
    48stude
    I have five carbs, 1 2GC and 4 2GV's and they all have the same holes( puzzled ) Bill
  5. blackout
    blackout
    68 Camaro has them. Unfiltered air drawn right in there.
  6. 51box
    51box
    from MA
    A friend of mine has been collecting 2gc parts to put a set up together and one of the bases has those holes. Seems strange to me like he said unfiltered air.
  7. el Scotto
    el Scotto
    from Tracy, CA
    Top Secret plot by GM to increase engine replacements? ;)
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    when that ****erfly closes..is it below it or above it?..(the hole)
    i have an idea
    if used in a multiple carb set up..like tri-power..or 4x2 6x2 etc,..as a non primary carb.
    the carb when at idle still ****s a little bit of fuel past the ****erfly..this helps add some air to the mix so it doesnt affect the idle mixture set on the carb used as the idle or primary carb..
    just my feel for it..i could be wrong, and im sure someone will tell me if i am
  9. 48stude
    48stude
    When the ****erfly is closed, the hole is above them. bill
  10. merf
    merf
    from new joisey
    Those holes are to vent the fuel vapors in a "hot soak" condition. When you shut the car off hot sometimes the gas cooks in the carb from the heat and the vapors go down the throat flooding the engine. They are supposed to let the fumes out to stink up your garage.
  11. 48stude
    48stude
    Merf, That sounds reasonable. Bill
  12. 48stude
    48stude
