i have looked at all of the post on here. i am trying to get a rebild kit for my 3x2 set up. the carbs have no tag and i see no ### any were on any of them..... need help
as far as I know the only place they are marked is on the tag. Remove the carb and take it into napa, and ask for someone who knows how to work a device called a "catalog" and look through it together, there should be a way to identify it with the pics in the manual. Another thing to keep in mind, is that in the past when I have purchased such a rebuild kit, I have gotten home only to find that there are like 5 of every gasket, each one having only a slight variation in layout and application. So I still had to lay them out and compare them to my old carb to find the correct gaskets. always seemed wastefull to me, but I bet if you got closse with the manual at the store, the kit you get will have at least one set of the correct parts! Good luck
every kit I've ever bought had all the parts for any 2 jet, just match the parts as you dis assemble and set the rest aside
Go get the kit and itll be right.The 2 jets i usually get dont have the tag but dont have to worry about it cause i know what kit works.If your parts outlet doesnt stock walker kits they'll surely be able to cross the walker number to kit they stock.
